Can’t Uninstall or Use anything to Mount
Sysprogs forums › Forums › WinCDEmu › Can’t Uninstall or Use anything to Mount
  • #223
    Frustrated
    So WinCDEmu did not install correctly the first time, did not work. I installed the software recommended here to fix whatever driver problem. At first it was visible for regular removal. Installed again and then it was visible but still did not work. Then removed it regularly. Did not remove, as right clicking an iso provides WinCDEmu menu. Can’t use any other mount software or uninstall completely. Please help, I appreciate the effort but I just want to my computer working again. Thanks.
    XP SP3
    #1543
    Please search for GearASPIWdm on this forum.
    If you want any other mounting software to work, simply reinstall it, so it updates file associations.
    #1544
    I appreciate the quick response!
    However, I already researched that and tried that. I can’t remove the context menu, which means I can’t edit the name of the file for use with a different mounter or view properties etc. CDEmu is frankly still on my system and I want it off. How do I do this?
    #1545
    Seriously, no help?
