Can't install CMAKE with sysprogs extensions
Sysprogs forums › Forums › VisualGDB › Can't install CMAKE with sysprogs extensions
  • #25584
    cyborgium
    I just installed visualGDB on a new machine but I’m stuck at installing cmake with the sysprogs extensions. While downloading the files, visual studio gives me the following error:
    “Some packages could not be installed: The underlying connection was closed: An unexpected error occurred on a receive. Please check the error log for more details.”
    This is the exception:
    VisualGDB version: 5.4.112.3242
    ------------------ i11+c ------------------
    i11+c: Some packages could not be installed: The underlying connection was closed: An unexpected error occurred on a receive.
    at i11.g1.g(rt1 a)
    at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass2_2`1.<RunAction>b__0()
    The output is as following:
    System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
    at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at l7.c_2()
    at fo2.e1()
    at mp2.c_2(EventWaitHandle b, Boolean a)
    at h4.w(Boolean c, Boolean a, Int32 b)
    What am I doing wrong?
    • This topic was modified 7 years, 1 month ago by cyborgium.
    #25587
    cyborgium
    Alright so an update, I tried it again after lunch and it magically worked.. However, I had a bluescreen while in the process of installing cmake. This bluescreen is a known issue on my particular machine, however now projects cannot be loaded. I suppose that the easiest way to solve this would be to reinstall cmake but I don’t know how to uninstall it or how to trigger the dialogue message asking whether I want to install it.
    Any ideas?
    #25588
    Good to know the installation succeeded. Most likely, the error was caused by some network issues.
    You can reinstall CMake via Tools->VisualGDB->Manage VisualGDB Packages or by removing the %LOCALAPPDATA%\VisualGDB\CMake folder.
