Can't debug after moving Linux servers
Sysprogs forums Forums VisualGDB Can't debug after moving Linux servers
  • #8337
    Nakueliofix
    There were 3 development Linux machines, 1,2,3.  Was using #2, and it was shut-down for reasons not fully disclosed to me.  However, it was working perfectly for debugging applications.  I’ve updated my projects to point to server #1 (And for trials, used #3 as well) but was unable to debug on either server.   Breakpoints worked fine, but viewing variables does not work at all, unless they are globals.
    The error I get is:
    VarName    mi_cmd_var_create: unable to create variable object
    This happens for all variables, preview/auto/locals.
    It may help to note that the Linux machines 1/2/3 are all clones of each other.
    This brings me to my 2nd issue – this forums search command does not work.  I click search and enter “mi_cmd_var_create” and get no results, but entering it into a search engine (Google, etc) and restricting results to this site yields a bunch of results.  None of which helped me figure out what’s going wrong, though.
    #8339
    This error means that the debug symbols for your module do not contain enough information to find the memory address of the requested variable. It can happen due to a variety of reasons:
    • Incompatibility between your gcc and gdb versions
    • Incompatibility between the debug information format (e.g. DWARF 4) and your gdb version
    • Missing “-ggdb” in your compilation flags
    • Symbols being stripped from the executable after it is built
    • Symbols not matching the loaded executables
    We would recommend setting up a “hello, world” project using the same build/debug machines, ensuring that it works and then comparing compiler flags and gdb versions with your actual project in order to find out what exact difference breaks the variable viewing.
    #8349
    Nakueliofix
    The answer was – Incompatibility between your gcc and gdb versions
    Thanks so much!
