Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Can’t connect to target
- This topic has 3 replies, 3 voices, and was last updated 12 years, 8 months ago by
Anonymous.
November 13, 2012 at 21:04 #439
borge
ParticipantHi, I hope you can help a newbie getting started with VirtualDDK.
I have two targets, a virtual Win7-32 in VMware and a physical Win7-32 with a nullmodem cable. VirtualBox is not stable with the kind of driver I wish to install.
The physical machine won’t boot with the [VirtualKD] [debugger enabled] option. But with normal boot, discovery request does show up in DDKLaunchMonitor. But the window named Connecting to kernel debugging session keeps saying “10 write to 0x1” without continuing.
On the VM things are rougher. Normal boot does not get discovery requests. [VirtualKD] boot gets discovery requests. But now Connecting to… says “Throttle 0x10 write to 0x1 n 8007803E1,1,0) fails.”
When I cancel the connection attempt to the physical machine it does not have consequenses. But when I cancle the attempt to the VM I get the message “The named pipe used for debugging is busy. If you have WinDbg open, please close it!”. This happens in spite of me not having selected a named pipe as the connection message, but rather a discovered VM.
The very first attempt with the VM did get me further, but no actual debuggint took place. Instead, certain drivers were put on the slow startup list. Now I can’t get back to that state. In the meantime I have rebooted all targets and the host multiple times.
Any help appreciated!
BorgeNovember 17, 2012 at 11:18 #2108borge
ParticipantThe one difference I see in my system compared to the tutorial is that %DDKPATH% is not set. I know the tutorial says it’s not needed. Still, that’s the one difference I see.
With VisualDDK 1.5.7 I see discovery requests on the target and timeouts on the host.
With VirtualKD 2.8 things seem to be functional.
My target is Win7-32 (VMware and physical machine) my host is Win7-64. Visual Studio 2010 Pro, WDK 7600.16385.1, Debug tools installed.
BørgeApril 17, 2013 at 12:43 #2107sally
ParticipantI also encounter the same problem as you are,have you solve it? If you have,please help me . Thank you very much!
July 16, 2013 at 05:42 #2109Anonymous
ParticipantI had same problem and solved this issue through below modify.
(Win7 Pro x64/VS2008/WDK7.1)1. Check Boot.int of Target PC ( Open C:Boot.ini with NOTEPAD )-> Unreadable Charater (Delete it).
C:Boot.ini
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS=”Microsoft Windows XP Professional [VirtualKD]” /DEBUG /DEBUGPORT=bazis /fastdetect /noexecute=optin2. Run VS2008 with Administration Privilege (Windows Vista ~ Windows 7). –> Development PC(Host)
3. Check Firewall Setting.–>Target PC.
