Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Cannot start debuging
- This topic has 20 replies, 3 voices, and was last updated 14 years, 7 months ago by
Anonymous.
May 30, 2011 at 07:35 #302
Saman
Cannot start debuging:System cannot find specified file.
so this error I get , when I launch a “Driver launch settings ” dialog.But I don’t know which file is it. Drivers file I have at shared folder for source and target machine and any other file is not asked.
Thanks for some idea.May 30, 2011 at 08:35 #1750support
KeymasterDo you have a Visual Studio project for the driver you are trying to debug? If not, use the Debug->Attach menu and deploy the drivers manually. The Driver Launcher will only autodeploy the drivers that are built in Visual Studio.
May 30, 2011 at 13:50 #1751Saman
ParticipantYes,
first I try the driver, which is created with VisualDDk wizard.May 30, 2011 at 14:04 #1752support
KeymasterDoes the driver building succeed? Or are there any error messages? Does the problem persist if you create a driver using Visual Studio build system (specified in the wizard)?
May 30, 2011 at 15:21 #1753Saman
ParticipantThe project was created without any error.The driver I create with File->New->Project->VisualDDkWiz.I try it at Visual 2010 and 2008 and problem is under both VS.
May 30, 2011 at 19:08 #1754support
KeymasterWhen you build the project, does it show any messages? Is the SYS file created?
May 30, 2011 at 19:51 #1755Saman
ParticipantBuild started: Project: VddK, Configuration: Debug Win32
Build started 30.5.2011 21:49:41.
Build:
path contains nonexistant c:program filesmicrosoft visual studio 10.0common7toolsbin, removing
path contains nonexistant c:windowssyswow64, removing
path contains nonexistant c:usersmirekdocumentsrad studio8.0bpl, removing
BUILD: Compile and Link for x86BUILD: Loading c:winddkbuild.dat…
BUILD: Computing Include file dependencies:
OACR monitor running already
BUILD: Start time: Mon May 30 21:49:42 2011
BUILD: Examining c:msvisprojectsvddkvddk directory for files to compile.c:msvisprojectsvddkvddk
Invalidating OACR warning log for ‘root:x86chk’
BUILD: Saving c:winddkbuild.dat…BUILD: Compiling and Linking c:msvisprojectsvddkvddk directory
BUILD: Finish time: Mon May 30 21:49:43 2011
BUILD: Done0 files compiled – 3 Warnings
Configuring OACR for ‘root:x86chk’ –
Build succeeded.
Time Elapsed 00:00:02.73
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========May 30, 2011 at 20:14 #1756support
KeymasterI am assuming, the “0 files compiled” message is the key one.
Have you updated the “sources” file?
BTW, you can simplify it by selecting “Use VIsual Studio build system” in the Driver Wizard, so that the created project won’t need the external build utility and the sources file.May 30, 2011 at 20:47 #1757Saman
ParticipantSorry, one more tine
Build started 30.5.2011 22:46:00.
Build:
BUILD: Start time: Mon May 30 22:46:02 2011
Auto-cleaning queue for ‘root:x86chk’ (2 of 2 file(s) removed)
Compiling – stdafx.cpp
Compiling – vddk.cpp
Compiling – generating code…
Linking Executable – objchk_win7_x86i386vddk.sys
BUILD: Finish time: Mon May 30 22:46:07 2011
BUILD: Done4 files compiled – 3 Warnings – 98 LPS
1 executable built
Build succeeded.
Time Elapsed 00:00:07.71
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========May 31, 2011 at 06:18 #1758support
KeymasterSo, is the SYS file created?
Did you also try “VS build system”?May 31, 2011 at 07:43 #1759Saman
Participant.SYS file is created.
I am sorry but I don’t know, where I find VS Build System.
And one basic question.Which files and where must be the files for source and target machine for successfull debuging the driver.I mean, that on target machine can be only .sys file at shared folder.Or I am not right.May 31, 2011 at 09:13 #1741support
KeymasterSee the radiobuttons in the bottom of the driver wizard dialog:
[attachment=0:152ahi4z]drvwiz.png[/attachment:152ahi4z]May 31, 2011 at 12:58 #1742Saman
ParticipantUnfortunatelly I get the same error, if I use VS Build system. :-((((((((((((((((((((
It is possible lookup, which file system cannot find?I lookup at Vs logfile but i don’t see any error.
Which files use VisualDDk debug at startup?
I can enter whatever at field Target machine or Driver path at target machine but always I get VisualDDk error:……May 31, 2011 at 13:15 #1743support
KeymasterCould you post a screenshot of the “Driver launch settings” dialog and the error message box?
May 31, 2011 at 14:17 #1744Saman
ParticipantSorry, I dont know how to add a picture at the message body so the screenshots are at attachments 🙁
