Cannot start CMake Debugger
Sysprogs forums Forums VisualGDB Cannot start CMake Debugger
  • This topic has 2 replies, 2 voices, and was last updated 4 years ago by quag.
  • #32276
    quag
    Hi, I am following this tutorial https://visualgdb.com/tutorials/cmake/debugger/  to debug cmake script.
    However, when I right-click the “Launch CMake Debugger”, first I get the warning: “Stepping through CMake scripts requires building CMake with Sysprogs extensions. Do you want to see the detailed instructions?”
    Then I get the error “Debugging fialed. VisualGDB has encountered a problem while starting debugging: No such host is known”. And no more details is available.
    For sysprogs extesion, the warning msg directs me to the link https://visualgdb.com/documentation/cmake/annotations/, but in the link it says “Install original CMake 3.14 or later” for which I checked the CMake version in WSL is 3.16 and in Windows is 3.21. Besides, it says in the link “If you are building your projects on Windows, VisualGDB will automatically install and use the advanced CMake build.”.
    Any help is appreciated!
    I am using Visual Studio 2019 under Windows 10, WSI as backend.
    <audio style=”display: none;” controls=”controls”></audio>
    #32280
    Debugging CMake files requires building our fork of CMake and will not work with the regular builds. Please refer to this page for more details.
    #32284
    quag
    I see, thanks for the quick reply!
