Cannot install VisualGDB on Win10 and VS2022
Sysprogs forums › Forums › VisualGDB › Cannot install VisualGDB on Win10 and VS2022
  • #31833
    peini7
    I’ll try VisualGDB but cannot install it since the installer fails when installing the VS extension.
    It tells me that i need higher permissions but i’am admin on my machine and UAC is completely turned off.
    I’am using the latest version of VisualGDB, just downloaded a few minutes ago.
    Here is some output of the installer log:
    Action 19:54:19: FinalizeVSIntegrationNormal. Updating Visual Studio package…
    SFXCA: Extracting custom action to temporary directory: C:\Users\danie\AppData\Local\Temp\MSI9D05.tmp-\
    SFXCA: Binding to CLR version v4.0.30319
    Calling custom action VisualGDBCustomActionLib!VisualGDBCustomActionLib.CustomActions.FinalizeVSIntegrationNormal
    Der angeforderte Vorgang erfordert erhöhte Rechte
    MSI (s) (0C!94) [19:54:20:598]: Product: VisualGDB — Der angeforderte Vorgang erfordert erhöhte Rechte
    CustomAction FinalizeVSIntegrationNormal returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
    Action ended 19:54:20: InstallFinalize. Return value 3.
    Action 19:54:20: Rollback. Rolling back action:
    Rollback: Updating Visual Studio package…
    Does anyone have an idea?
    Thank you.
    • This topic was modified 4 years, 9 months ago by peini7.
    #31835
    peini7
    Ah.. Solved it.
    For everyone having the same problem.. Running the installer from an adminstrator command promt did the trick, because there is no “Run as administrator”-button on msi-files.
    #31836
    Good to know it works. Normally, the Windows installer will automatically show the administrator prompt during the installation, however some group policy settings or 3rd-party antivirus software might indeed interfere with it. If you have not changed any security-related settings, this could be an indication that some system files got corrupt.
