Sysprogs forums › Forums › VisualGDB › Cannot debug anyone in one project
- This topic has 7 replies, 2 voices, and was last updated 8 years ago by
JoeWright.
March 23, 2018 at 23:51 #20540
JoeWright
ParticipantOne project that was previously working fine, now refuses to launch the debugger (stops just before it should flash). The odd thing is, a more recently created project, with identical settings, still works fine.
Here is the output:
C:\Users\Joe\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 51213” -c “telnet_port 51214” -f interface/stlink-v2.cfg -f target/stm32f3x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2017-10-27) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v28 API v2 SWIM v6 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.228402
Info : stm32f3x.cpu: hardware has 6 breakpoints, 4 watchpoints
adapter speed: 950 kHz
xPSR: 0x01000000 pc: 0x0800fc30 msp: 0x20006000
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
adapter speed: 4000 kHz
Info : accepting ‘gdb’ connection on tcp/51213
Info : device id = 0x20006432
Info : flash size = 128kbytes
Info : dropped ‘gdb’ connection (error -400)In general, I’m finding that projects can get into these funny corrupted states. I don’t know if it’s my habit of hibernating that is causing problems, because I know visualgdb has issues with this. But recently there was an update to the toolchain or whatever, and it didn’t work properly. I had to delete and re-download. The project which was opened at the time refused to work properly after that.
Obviously I can create new projects each time there’s a problem, but its a bit annoying. Would like some sort of project clean-up function perhaps.
Joe
March 24, 2018 at 04:22 #20541support
Strange, the log doesn’t indicate any known error. As a quick check, does restarting your computer solve the problem?
March 24, 2018 at 17:26 #20542JoeWright
ParticipantNo, I did a full reboot but it did not help. Loading up the two different projects – one works, one doesn’t. Went in and checked the gdb settings were the same and they were (as far as I can tell). Have also tried switching off the firewall but that didn’t work either.
March 25, 2018 at 17:00 #20544JoeWright
ParticipantDid an ignore and then looked at the gdb session details:
VisualGDB is licensed to Joe Wright
C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi E:\projects\IMU\STM32_Projects\Handle_6\VisualGDB\Debug\Handle_6
-gdb-version
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 8.0.1\n”
~”Copyright (C) 2017 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
This GDB was configured as “–host=i686-w64-mingw32 –target=arm-eabi”.
~”For help, type \”help\”.\n”
~”Reading symbols from E:\\projects\\IMU\\STM32_Projects\\Handle_6\\VisualGDB\\Debug\\Handle_6…”
~”done.\n”
^done
-list-features
-gdb-set print demangle off
^done
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08013302″,func=”main()”,file=”Src/main.cpp”,fullname=”E:\\projects\\IMU\\STM32_Projects\\Handle_6\\Src\\main.cpp”,line=”219″,thread-groups=[“i1″],times=”0″,original-location=”main”}
set remotetimeout 60
&”set remotetimeout 60\n”
=cmd-param-changed,param=”remotetimeout”,value=”60″
^done
target remote :55440
&”target remote :55440\n”
~”Remote debugging using :55440\n”
~”../../gdb-8.0.1/gdb/frame.c:542: internal-error: frame_id get_frame_id(frame_info*): Assertion `stashed’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? ”
~”(y or n) [answered Y; input not from terminal]\n”
&”\nThis is a bug, please report it.”
&” For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>.”
&”\n\n”
~”../../gdb-8.0.1/gdb/frame.c:542: internal-error: frame_id get_frame_id(frame_info*): Assertion `stashed’ failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? ”
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.March 25, 2018 at 23:49 #20545support
Thanks for sharing the log. This looks like an internal bug of the gdb debugger included in your toolchain. Please try using a different gdb version (e.g. from an older toolchain), or try changing the debug information format in your project properties as this might stop the bug from being triggered.
March 26, 2018 at 00:16 #20547JoeWright
ParticipantOk, I’ve just changed it to dwarf 2, and it worked. Then changed it back to gdb optimised and it still worked! Obviously that tidied up something that a clean and rebuild didn’t. So all working now, thanks.
Btw, the version of gdb that I’m using is whatever comes with visualgdb. Wouldn’t know where to start with going to an older version but since its working now, I’ll leave alone.
Thanks, Joe
March 26, 2018 at 19:57 #20550support
Yes, we indeed ship the pre-built recent versions of the GNU tools like GCC and GDB, however unfortunately resolving the internal bugs of those tools is beyond what we can offer. Hence our best advice for this type of problems (if you run into it again and cannot resolve it via compiler settings) would be to downgrade to a previous gdb release until we release another pre-built version based on newer sources.
You can always download the older toolchain versions here: http://gnutoolchains.com/arm-eabi/
Simply copy the arm-eabi-gdb.exe executable from an older toolchain to the newer one and you will be able to use the newest toolchain (including all optimization features it offers) with the old gdb debugger.
March 27, 2018 at 11:54 #20554JoeWright
ParticipantAh ok, thanks.
