Cannot debug Android executable on Nexus 5X
Sysprogs forums Forums VisualGDB Cannot debug Android executable on Nexus 5X
  • #11716
    victorpsbg
    Greetings,
    I have a fresh VisualGDB, Android SDK and Android NDK installation. The only toolchain that shows up is 4.9. When I run the Android Device Compatibility Center, I see that my device, a Nexus 5X, shows up as Platform version 25. The NDK version, strangely, shows up as 0. When I run the test I get an immediate build failed message with the following log:
    VisualGDB: Run “C:\android-sdk\ndk-bundle\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-25” in directory “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-12332\4.9” on local computer
    Android NDK: APP_PLATFORM set to unknown platform: android-25.
    C:/android-sdk/ndk-bundle/build//../build/core/setup-app-platform.mk:115: *** Android NDK: Aborting . Stop.
    Command exited with code 2
    Executable: C:\android-sdk\ndk-bundle\ndk-build.cmd
    Arguments: NDK_DEBUG=1 APP_PLATFORM=android-25
    Directory: C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-12332\4.9
    VisualGDB: Error: Command-line action failed
    Build failed: Build failed
    I am running Android 7.1.2 and I’m very confident this setup worked a year ago when I my phone had Android 6.
    Thanks!
    #11725
    This looks like our bug. Please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.3.1675.msi
    #11727
    victorpsbg
    New logs:
    VisualGDB: Run “C:\android-sdk\ndk-bundle\ndk-build.cmd NDK_DEBUG=1 APP_PLATFORM=android-24” in directory “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9” on local computer
    Android NDK: WARNING: APP_PLATFORM android-24 is higher than android:minSdkVersion 3 in ./AndroidManifest.xml. NDK binaries will *not* be comptible with devices older than android-24. See https://android.googlesource.com/platform/ndk/+/master/docs/user/common_problems.md for more information.
    [arm64-v8a] Gdbserver : [aarch64-linux-android-4.9] libs/arm64-v8a/gdbserver
    [arm64-v8a] Gdbsetup : libs/arm64-v8a/gdb.setup
    [arm64-v8a] Compile : first <= first.c
    [arm64-v8a] Compile : first <= gdbserver_launcher.c
    [arm64-v8a] SharedLibrary : libfirst.so
    [arm64-v8a] Install : libfirst.so => libs/arm64-v8a/libfirst.so
    [arm64-v8a] Compile : second <= second.c
    [arm64-v8a] SharedLibrary : libsecond.so
    [arm64-v8a] Install : libsecond.so => libs/arm64-v8a/libsecond.so
    VisualGDB: build.xml/local.properties not found in C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9. Running “android update project” to generate it…
    VisualGDB: Run “C:\android-sdk\tools\android.bat update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9″” in directory “” on local computer
    The “android” command is deprecated.
    For manual SDK, AVD, and project management, please use Android Studio.
    For command-line tools, use tools\bin\sdkmanager.bat
    and tools\bin\avdmanager.bat
    Invalid or unsupported command “update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9″”
    Supported commands are:
    android list target
    android list avd
    android list device
    android create avd
    android move avd
    android delete avd
    android list sdk
    android update sdk
    Command exited with code 1
    Executable: C:\android-sdk\tools\android.bat
    Arguments: update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9”
    Directory:
    VisualGDB: Error: Default build failed. Trying to force target to android-14 . Please rebuild the project.
    VisualGDB: Run “C:\android-sdk\tools\android.bat update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9″ –target android-14” in directory “” on local computer
    Invalid or unsupported command “update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9″ –target android-14”
    android list target
    android list avd
    android list device
    android create avd
    android move avd
    android delete avd
    android list sdk
    android update sdk
    Arguments: update project –path “C:\Users\Admin\AppData\Local\Temp\SysprogsAndroidTest-20708\4.9” –target android-14
    Directory:
    • This reply was modified 8 years, 8 months ago by victorpsbg.
    #11759
    This happens because the latest Android SDK removes support for Ant-based builds and only supports Gradle/CMake for C++ code.
    As a workaround please try using this SDK: https://dl.google.com/android/repository/tools_r25.2.5-windows.zip
    We will look into extending our new CMake project subsystem to Android projects after the final VisualGDB 5.3 release; until then please use the older SDK as a workaround.
    #11804
    victorpsbg
    EDIT: Just saw your edited comment, testing.
    EDIT2: Workaround confirmed, thanks for sharing! Looking forward to official CMake support 🙂
    • This reply was modified 8 years, 7 months ago by victorpsbg.
