Can not debug Raspberry Pico target using remote Raspberry Pi
Sysprogs forums › Forums › VisualGDB › Can not debug Raspberry Pico target using remote Raspberry Pi
  • #33314
    obi
    Hi
    I am trying to debug Raspberry Pico W using openOCD running on Raspberry Pi using Visual Studio and VisualGDB.
    First, I am able to debug the Pico when I run GDB locally on the Raspberry Pi. My conclusion is therefore that all wiring is correct.
    When I try to debug using VisualStudio and VisualGDB it does not work and it seems like the program throws an exception. Please see the attached screen shots.
    #33316
    obi
    The second screen capture was to big to attach, here it is.
    #33318
    Based on the screenshot you attached, you have 2 instances of OpenOCD running simultaneously (one in the terminal and another launched via VisualGDB). This will indeed not work, as they will conflict with each other.
    Please make sure you only have one instance at a time.
