Can I debug Grove Vision AI Module V2?
Sysprogs forums Forums VisualGDB Can I debug Grove Vision AI Module V2?
  • #35784
    m_kramar
    Hi guys!
    I’m thinking to evaluate this board: https://github.com/HimaxWiseEyePlus/Seeed_Grove_Vision_AI_Module_V2
    I used to work with VisualGDB before.
    I’m now thinking if I could use VisualGDB to debug this thing?
    Misha
    #35785
    We have not specifically tested VisualGDB with this board. However, if it comes with a functional toolchain and the gdb debugger (i.e. you can build and debug a project manually), you can easily point VisualGDB to the same tools and let it drive building and debugging for you,
    #35792
    m_kramar
    Thanks for that!
    Can you point me in the direction of where I can start configuring this setup?
    Given that I have very little experience with VisualGDB.
    #35794
    Please make sure you can get it working outside VisualGDB first. Once it is working, feel free to share the details about your setup, and we will point you to the relevant VisualGDB documentation.
