Sysprogs forums › Forums › VisualGDB › C99 support
- This topic has 3 replies, 4 voices, and was last updated 10 years, 1 month ago by
April 3, 2014 at 14:58 #775
mru22
ParticipantSome of the code I am writing is throwing errors indicating that it requires C99. Is there a way I change the Visual GDB Build settings to use C99 ?
thanks,
April 4, 2014 at 19:08 #3029ket
Please add to CFLAGS on the Makefile settings page of VisualGDB Project Properties the following flag:
-std=c99If you are using your own makefile, then add it to the makefile in an equivalent location so that the flag is passed to gcc.
March 10, 2016 at 13:47 #7746igorfranco
ParticipantHello,
I’m porting Z80 code made in C99 to ARM platform, I changed my compiler directive according you suggested, but unfortunately I’m still facing compiler problems like below:
I do appreciate if some bright soul could help me in this issue.
Error cannot convert ‘unsigned char (*)[17]’ to ‘char*’ for argument ‘1’ to ‘void lcd_str(char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 325
Error cannot convert ‘unsigned char (*)[17]’ to ‘char*’ for argument ‘1’ to ‘void lcd_str(char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 383
Error cannot convert ‘unsigned char (*)[17]’ to ‘char*’ for argument ‘1’ to ‘void lcd_str(char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 489
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 700
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 761
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 765
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 774
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 778
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 785
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 789
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 796
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 800
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 806
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void bput_str(char*, char, char, char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\DIAG.C 810
Error cannot convert ‘unsigned int*’ to ‘const char*’ for argument ‘2’ to ‘char* strcpy(char*, const char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2270
Error cannot convert ‘unsigned int*’ to ‘const char*’ for argument ‘2’ to ‘char* strcpy(char*, const char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2271
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void get_clas(char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2715
Error cannot convert ‘unsigned int*’ to ‘char*’ for argument ‘1’ to ‘void get_clas(char*)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2728
Error aggregate ‘typ_peles peles_temp1’ has incomplete type and cannot be defined MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2754
Error aggregate ‘typ_peles peles_temp2’ has incomplete type and cannot be defined MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2755
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2763
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void get_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2775
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2778
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2810
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2811
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2813
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2814
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2815
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2816
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2817
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2819
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2840
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2843
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2856
Error invalid use of incomplete type ‘struct typ_medida’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2859
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void get_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2903
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2932
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void get_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2968
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void get_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2982
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 2999
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void get_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 3067
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 3078
Error no match for ‘operator=’ (operand types are ‘typ_nvr::typ_peles’ and ‘typ_peles’) MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 3142
Error cannot convert ‘typ_nvr::typ_peles*’ to ‘typ_peles*’ for argument ‘1’ to ‘void put_medida(typ_peles*, int)’ MD_SORT_ARM_2015_C H:\Firmware\MD_SORT\4.09a\InitialSource\ESTEIRA.C 3164March 11, 2016 at 19:30 #7757support
It’s hard to say why these errors are happening if you are using C99. Could you please share the full build log from the Output window? Perhaps you have enabled strict type checking via CFLAGS?
