C++17 support
Sysprogs forums Forums VisualGDB C++17 support
  • #25704
    janulo
    is it ok to use C++17 standard, even if it’s marked as “experimental”? AFAIK it should be fully supported by GCC7.2.0.
    Environment:
    • VisualGDB Custom Edition, version 5.4R12
    • GCC7.2.0 (arm-eabi)
    • target: STM32L4
    • standalone project
    #25705
    From the VisualGDB side, there are no limitations regarding the C++17 support. As long as you are satisfied with the level of support provided by the GCC version you are using, it should be totally OK.
    The ‘experimental’ label was added to VisualGDB settings when the C++17 support was still incomplete in most of GCC releases and should not apply to the latest GCC anymore. We have updated VisualGDB internally to remove the ‘experimental’ label.
    #25706
    janulo
    Thank you, great
