Sysprogs forums › Forums › VisualGDB › Building and debugging cmake app
- This topic has 5 replies, 4 voices, and was last updated 12 years, 10 months ago by
April 2, 2013 at 09:09 #544
kbzowski
ParticipantHi, what is the correct solution to import existing cmake based application and work with it?
Right now I am importing source, and after that run cmake to create MakeFile. Is it correct? Will I need import project again when I will modify CMakeLists.txt (by adding new files)?
Using that method I cannot run out-of-source build (MakeFile is located in different directory than source files).
I am working in environment without any directories shared between Linux and Windows platforms.April 8, 2013 at 17:10 #2321ket
ParticipantDo not copy the source files to a new location from the Makefile location, the source tree shown in Visual Studio projects is only for the convenience of sorting and opening the files and does not refer to the physical location. Adding new files to the project only adds the files automatically to the Makefile if you are using the VisualGDB generated Makefile. You do not need to import the project again if you add files to CMakeLists.txt, importing is just meant for the convenience of importing the entire source at the beginning of a project. Putting it all together, import the source and Makefile, CMakeLists.txt when making the project, make sure the project builds, when adding files later on, make sure you also add them in the Makefile.
Better handling of CMake projects is currently being considered as a feature for the next VisualGDB version. If you have any feature suggestions, let us know.
May 21, 2013 at 16:08 #2322Anonymous
ParticipantIn current version CMake-based build runs as expected, but out-of-source cmake builds lead to VisualGDB “warning VGDB001: Inconsistent depth reported by GNU Make”. It would be great if VisualGDB will suppress such warnings if case of CMake projects.
May 25, 2013 at 23:42 #2323support
KeymasterCould you paste a typical build log showing the problem here? Looks like cmake uses a different format for “entering directory”/”leaving directory” messages and this confuses VisualGDB.
June 4, 2013 at 16:45 #2324Anonymous
ParticipantSorry for the late reply. I’ve just checked this topic again.
I’ve root-caused the warning source. It have nothing to do with cmake, but rather make option -j8, which parallels build (and speedup it appropriately 🙂 ) causes warning. Seems in current version VisualGDB expects single-thread build process.36> VisualGDB: Attempting inline build...
36> VisualGDB remote project path: /home/user/projectname/src
36> No file changes detected. If you believe it's a mistake, please clean the project and build it again.
36> make -j8 -C __cmake/intel64.make.debug
36> make: Entering directory `/home/user/projectname/src/__cmake/intel64.make.debug'
36> /usr/bin/cmake -H/home/user/projectname/src -B/home/user/projectname/src/__cmake/intel64.make.debug --check-build-system CMakeFiles/Makefile.cmake 0
36> /usr/bin/cmake -E cmake_progress_start /home/user/projectname/src/__cmake/intel64.make.debug/CMakeFiles /home/user/projectname/src/__cmake/intel64.make.debug/CMakeFiles/progress.marks
36> make -f CMakeFiles/Makefile2 all
36> make[1]: Entering directory `/home/user/projectname/src/__cmake/intel64.make.debug'
36> make -f samples/sample_common/CMakeFiles/sample_common_type1.dir/build.make samples/sample_common/CMakeFiles/sample_common_type1.dir/depend
36> make -f samples/sample_common/CMakeFiles/sample_common_type2.dir/build.make samples/sample_common/CMakeFiles/sample_common_type2.dir/depend
36> make -f samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/build.make samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/depend
36> make -f _studio/prj_lib/CMakeFiles/prj_lib_merged.dir/build.make _studio/prj_lib/CMakeFiles/prj_lib_merged.dir/depend
36> make -f _studio/prj_lib/CMakeFiles/prj_lib_merged_hw.dir/build.make _studio/prj_lib/CMakeFiles/prj_lib_merged_hw.dir/depend
36> make -f _studio/prj_lib/CMakeFiles/prj_lib_merged_sw.dir/build.make _studio/prj_lib/CMakeFiles/prj_lib_merged_sw.dir/depend
36> make[2]: Entering directory `/home/user/projectname/src/__cmake/intel64.make.debug'
36> cd /home/user/projectname/src/__cmake/intel64.make.debug && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/projectname/src /home/user/projectname/src/samples/sample_utilities/some_plugin /home/user/projectname/src/__cmake/intel64.make.debug /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_utilities/some_plugin /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/DependInfo.cmake --color=
36>EXEC : warning VGDB001: Inconsistent depth reported by GNU Make
36> cd /home/user/projectname/src/__cmake/intel64.make.debug && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/projectname/src /home/user/projectname/src/samples/sample_common /home/user/projectname/src/__cmake/intel64.make.debug /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_common /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_common/CMakeFiles/sample_common_type1.dir/DependInfo.cmake --color=
36> cd /home/user/projectname/src/__cmake/intel64.make.debug && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/projectname/src /home/user/projectname/src/samples/sample_common /home/user/projectname/src/__cmake/intel64.make.debug /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_common /home/user/projectname/src/__cmake/intel64.make.debug/samples/sample_common/CMakeFiles/sample_common_type2.dir/DependInfo.cmake --color=
36> cd /home/user/projectname/src/__cmake/intel64.make.debug && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/user/projectname/src /home/user/projectname/src/_studio/prj_lib /home/user/projectname/src/__cmake/intel64.make.debug /home/user/projectname/src/__cmake/intel64.make.debug/_studio/prj_lib /home/user/projectname/src/__cmake/intel64.make.debug/_studio/prj_lib/CMakeFiles/prj_lib_merged.dir/DependInfo.cmake --color=
36> make[2]: Leaving directory `/home/user/projectname/src/__cmake/intel64.make.debug'
36> make -f samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/build.make samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/build
36> make -f samples/sample_common/CMakeFiles/sample_common_type2.dir/build.make samples/sample_common/CMakeFiles/sample_common_type2.dir/build
36> make[2]: Nothing to be done for `samples/sample_utilities/some_plugin/CMakeFiles/some_plugin.dir/build'.
June 5, 2013 at 01:19 #2325support
Yes, VisualGDB expects the single-threaded output as it’s the only way to detect the full path of files (so that Visual Studio can show them) when GCC reports the relative path. If this is not a problem for you, you can safely ignore those warnings.
