Sysprogs forums › Forums › VisualGDB › Build Error with STM32CubeMX generated code
- This topic has 15 replies, 5 voices, and was last updated 8 years, 9 months ago by
January 31, 2017 at 20:48 #10245
meldano
got following error message:
Fehler MSB3073 Der Befehl “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\STM32F0.vcxproj” “/solution:C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\STM32F0.sln” “/config:Debug” “/platform:Win32″” wurde mit dem Code 1 beendet. STM32F0 C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets 41
Any Idea???
Many thanks
February 1, 2017 at 05:52 #10253support
Yes, please check the Output window (View->Output). It should contain the detailed build log listing all errors printed by the compiler, linker and other tools. If you are not sure, please post the log contents here and we will help.
February 1, 2017 at 06:21 #10255meldano
here is the output
1> VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug” in directory “C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0” on local computer
1>C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\Makefile(429): warning : overriding recipe for target `Debug/system_stm32f0xx.o’
1>C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\Makefile(185): warning : ignoring old recipe for target `Debug/system_stm32f0xx.o’
1> make: *** No rule to make target../../../STM32F0Discovery/STM32F0/Src/system_stm32f0xx.c', needed byDebug/system_stm32f0xx.o’. Stop.
1> ————————————————————-
1> Command exited with code 2
1> Executable: cmd.exe
1> Arguments: /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug
1> Directory: C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(41,5): error MSB3073: Der Befehl “”C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\STM32F0.vcxproj” “/solution:C:\Users\daniel\Desktop\STM32F0Discovery\STM32F0\STM32F0.sln” “/config:Debug” “/platform:Win32″” wurde mit dem Code 1 beendet.
========== Erstellen: 0 erfolgreich, 1 fehlerhaft, 0 aktuell, 0 übersprungen ==========-
This reply was modified 9 years, 2 months ago by
meldano.
February 1, 2017 at 16:47 #10261support
Looks like you have first imported the system_stm32f0xx.c file to the project and then deleted it. Please either remove the non-existing file from Solution Explorer, or restore it on the disk.
February 1, 2017 at 20:01 #10264meldano
ParticipantWill try it – thanks.
But I follow to 100% your tutorial…
February 2, 2017 at 08:41 #10284meldano
ParticipantDouble checked it. The file exist.
Is it possible to check my VS2015 Solution?
https://1drv.ms/u/s!AspuupI-wTK0h1ZPlDPqyDqNyxBF
February 3, 2017 at 02:29 #10291Stollerk
ParticipantHi!
I have the same error every time I try to build a project from STMCubeMX.
Here is my Output from my STM32L100 Discovery Project (but as I said it happens with every project imported from STMCubeMX):
1>—— Build started: Project: Disc2, Configuration: Debug Win32 ——
1> VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug -j4″ in directory “C:\VISUAL\Disc2” on local computer
1>C:\VISUAL\Disc2\Makefile(441): warning : overriding recipe for target `Debug/system_stm32l1xx.o’
1>C:\VISUAL\Disc2\Makefile(185): warning : ignoring old recipe for target `Debug/system_stm32l1xx.o’
1> C:\SysGCC\arm-eabi/bin/arm-eabi-g++.exe -o Debug/Disc2.elf -Wl,-gc-sections –specs=nano.specs -TC:\Users\krisz\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32/STM32L1xxxx/LinkerScripts/STM32L100RC_flash.lds -mcpu=cortex-m3 -mthumb -LC:\Users\krisz\AppData\Local\VisualGDB\EmbeddedBSPs\arm-eabi\com.sysprogs.arm.stm32\STM32L1xxxx\CMSIS_HAL\Include -Wl,–start-group Debug/system_stm32l1xx.o Debug/startup_stm32l100xc.o Debug/stm32l1xx_hal.o Debug/stm32l1xx_hal_adc.o Debug/stm32l1xx_hal_adc_ex.o Debug/stm32l1xx_hal_comp.o Debug/stm32l1xx_hal_cortex.o Debug/stm32l1xx_hal_crc.o Debug/stm32l1xx_hal_cryp.o Debug/stm32l1xx_hal_cryp_ex.o Debug/stm32l1xx_hal_dac.o Debug/stm32l1xx_hal_dac_ex.o Debug/stm32l1xx_hal_dma.o Debug/stm32l1xx_hal_flash.o Debug/stm32l1xx_hal_flash_ex.o Debug/stm32l1xx_hal_flash_ramfunc.o Debug/stm32l1xx_hal_gpio.o Debug/stm32l1xx_hal_i2c.o Debug/stm32l1xx_hal_i2s.o Debug/stm32l1xx_hal_irda.o Debug/stm32l1xx_hal_iwdg.o Debug/stm32l1xx_hal_lcd.o Debug/stm32l1xx_hal_nor.o Debug/stm32l1xx_hal_opamp.o Debug/stm32l1xx_hal_opamp_ex.o Debug/stm32l1xx_hal_pcd.o Debug/stm32l1xx_hal_pcd_ex.o Debug/stm32l1xx_hal_pwr.o Debug/stm32l1xx_hal_pwr_ex.o Debug/stm32l1xx_hal_rcc.o Debug/stm32l1xx_hal_rcc_ex.o Debug/stm32l1xx_hal_rtc.o Debug/stm32l1xx_hal_rtc_ex.o Debug/stm32l1xx_hal_sd.o Debug/stm32l1xx_hal_smartcard.o Debug/stm32l1xx_hal_spi.o Debug/stm32l1xx_hal_spi_ex.o Debug/stm32l1xx_hal_sram.o Debug/stm32l1xx_hal_tim.o Debug/stm32l1xx_hal_tim_ex.o Debug/stm32l1xx_hal_uart.o Debug/stm32l1xx_hal_usart.o Debug/stm32l1xx_hal_wwdg.o Debug/stm32l1xx_ll_adc.o Debug/stm32l1xx_ll_comp.o Debug/stm32l1xx_ll_crc.o Debug/stm32l1xx_ll_dac.o Debug/stm32l1xx_ll_dma.o Debug/stm32l1xx_ll_exti.o Debug/stm32l1xx_ll_fsmc.o Debug/stm32l1xx_ll_gpio.o Debug/stm32l1xx_ll_i2c.o Debug/stm32l1xx_ll_opamp.o Debug/stm32l1xx_ll_pwr.o Debug/stm32l1xx_ll_rcc.o Debug/stm32l1xx_ll_rtc.o Debug/stm32l1xx_ll_sdmmc.o Debug/stm32l1xx_ll_spi.o Debug/stm32l1xx_ll_tim.o Debug/stm32l1xx_ll_usart.o Debug/stm32l1xx_ll_utils.o Debug/main.o Debug/stm32l1xx_hal_msp.o Debug/stm32l1xx_it.o Debug/system_stm32l1xx.o -Wl,–end-group
1> Debug/system_stm32l1xx.o:(.data+0x0): multiple definition of `SystemCoreClock’
1> Debug/system_stm32l1xx.o:(.data+0x0): first defined here
1> Debug/system_stm32l1xx.o:(.rodata+0x0): multiple definition of `PLLMulTable’
1> Debug/system_stm32l1xx.o:(.rodata+0x0): first defined here
1> Debug/system_stm32l1xx.o:(.rodata+0xc): multiple definition of `AHBPrescTable’
1> Debug/system_stm32l1xx.o:(.rodata+0xc): first defined here
1> Debug/system_stm32l1xx.o:(.rodata+0x1c): multiple definition of `APBPrescTable’
1> Debug/system_stm32l1xx.o:(.rodata+0x1c): first defined here
1> Debug/system_stm32l1xx.o: In function `SystemInit’:
1> system_stm32l1xx.c:(.text.SystemInit+0x0): multiple definition of `SystemInit’
1> Debug/system_stm32l1xx.o:system_stm32l1xx.c:(.text.SystemInit+0x0): first defined here
1> Debug/system_stm32l1xx.o: In function `SystemCoreClockUpdate’:
1> system_stm32l1xx.c:(.text.SystemCoreClockUpdate+0x0): multiple definition of `SystemCoreClockUpdate’
1> Debug/system_stm32l1xx.o:system_stm32l1xx.c:(.text.SystemCoreClockUpdate+0x0): first defined here
1> make: *** [Debug/Disc2.elf] Error 1
1> Arguments: /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug -j4
1> Directory: C:\VISUAL\Disc2
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(41,5): error MSB3073: The command “”C:\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\VISUAL\Disc2\Disc2.vcxproj” “/solution:C:\VISUAL\Disc2\Disc2.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========I have also checked your VS2015 Solution with same resutls:
1>—— Build started: Project: STM32F0, Configuration: Debug Win32 ——
1> Updating C:\VISUAL\STM32Discovery\STM32F0\Makefile
1> VisualGDB: Updated source file list in C:\VISUAL\STM32Discovery\STM32F0\Makefile. Enable verbose mode for more details.
1> VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug” in directory “C:\VISUAL\STM32Discovery\STM32F0” on local computer
1>C:\VISUAL\STM32Discovery\STM32F0\Makefile(429): warning : overriding recipe for target `Debug/system_stm32f0xx.o’
1>C:\VISUAL\STM32Discovery\STM32F0\Makefile(185): warning : ignoring old recipe for target `Debug/system_stm32f0xx.o’
1> make: *** No rule to make target../../../AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F0xxxx/CMSIS_HAL/Device/ST/STM32F0xx/Source/Templates/system_stm32f0xx.c', needed byDebug/system_stm32f0xx.o’. Stop.
1> Directory: C:\VISUAL\STM32Discovery\STM32F0
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(41,5): error MSB3073: The command “”C:\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\VISUAL\STM32Discovery\STM32F0\STM32F0.vcxproj” “/solution:C:\VISUAL\STM32Discovery\STM32F0\STM32F0.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========I have tried this with VS2015 and VS2015 Pro RC. Both of them are fresh installations so I think it is that something is not properly installed. (Please consider this too.)
Stollerk.
February 3, 2017 at 05:21 #10294support
We have rechecked the sample project and it had 2 references to the system_stm32f0xx.c file: one from the BSP and another one from the STM32CubeMX project.
Please remove the reference to the one from the BSP via VisualGDB Project Properties -> Embedded Frameworks -> Default System file, then rebuild the project (Build->Rebuild All). This should get the build to work.
February 3, 2017 at 08:38 #10297meldano
Participant@support: Thanks!
Please make a note to your tutorial.
daniel
February 3, 2017 at 16:06 #10298Stollerk
ParticipantHi!
Thanks it solved the problem .
I have went further and now tried to import a project using FreeRTOS for STM32L152CBTx-A from STMCubeMX, and now I have a different error:
1>C:\VISUAL\STM32L152CBTxA\Middlewares\Third_Party\FreeRTOS\Source\portable\IAR\ARM_CM3\portmacro.h(147,25): error : intrinsics.h: No such file or directory
1> #include <intrinsics.h>
1> ^
1> compilation terminated.
1> make: *** [Debug/list.o] Error 1
1> Directory: C:\VISUAL\STM32L152CBTxA
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(41,5): error MSB3073: The command “”C:\Sysprogs\VisualGDB\\VisualGDB.exe” /build “C:\VISUAL\STM32L152CBTxA\STM32L152CBTxA.vcxproj” “/solution:C:\VISUAL\STM32L152CBTxA\STM32L152CBTxA.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========Here is the link for mySTMCubeMX file:
https://1drv.ms/u/s!AsDt__ew6eSNh7EM1pt1irGtbn6Y6Q
For me it looks like the missing intrinsics.h belongs to the complier.
Thanks.
Stollerk.
February 4, 2017 at 03:53 #10302support
Looks like your project includes files meant for the IAR compiler (IAR\ARM_CM3\portmacro.h). Please double-check the list of imported files and the preprocessor macros and ensure that only files meant for GCC are included.
If you are using Clang IntelliSense, you can quickly check why a certain file was included by opening it in Visual Studio and checking the bar on top of the source file. It will show the source file that includes the header and the entire inclusion stack.
February 7, 2017 at 10:33 #10329Stollerk
ParticipantThank you, it’s working now.
February 7, 2017 at 18:46 #10331Taisen
ParticipantCould you write a new tutorial on import the cubeMx? I had same error…
February 8, 2017 at 05:35 #10339support
We do have a tutorial on that already: https://visualgdb.com/tutorials/arm/stm32/cube/
July 4, 2017 at 09:38 #11641Mixaz29
ParticipantHi
In my project i use VS Community 2017 and Visualgdb 5.2R9.
After import project from STMCube v4.21.0 during compilation i received an error MSB3073.
Output window:
1>—— Сборка начата: проект: test1, Конфигурация: Debug Win32 ——
1>VisualGDB: Run “cmd.exe /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug” in directory “C:\vp\test1\test1” on local computer
1>C:\vp\test1\test1\Makefile(473): warning : overriding recipe for target `Debug/system_stm32f3xx.o’
1>C:\vp\test1\test1\Makefile(185): warning : ignoring old recipe for target `Debug/system_stm32f3xx.o’
1>make: *** No rule to make targetDebug/Program', needed byDebug/test1.elf’. Stop.
1>————————————————————-
1>Command exited with code 2
1>Executable: cmd.exe
1>Arguments: /c “C:\SysGCC\arm-eabi\bin\make.exe” CONFIG=Debug
1>Directory: C:\vp\test1\test1
1>VisualGDB : error : Command-line action failedcan you help?
