Sysprogs forums › Forums › VisualGDB › BUGGED selection of MinGW-w64 toolchain
- This topic has 3 replies, 2 voices, and was last updated 7 years, 6 months ago by
July 22, 2018 at 16:14 #21427
b.timofte
ParticipantHI all
I am trying to use Mathworks MinGW-w64 compiler
“C:\ProgramData\MATLAB\SupportPackages\R2018a\3P.instrset\mingw_w64.instrset\bin>gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=c:/ProgramData/MATLAB/SupportPackages/R2018a/3P.instrset/mingw_w64.instrset/bin/../libexec/gcc/x86_64-w64-mingw32/5.3.0/lto-wrapper.exe
Target: x86_64-w64-mingw32
Configured with: ../../../src/gcc-5.3.0/configure –host=x86_64-w64-mingw32 –build=x86_64-w64-mingw32 –target=x86_64-w64-mingw32 –prefix=/mingw64 –with-sysroot=/c/mingw530/x86_64-530-posix-seh-rt_v4-rev0/mingw64 –with-gxx-include-dir=/mingw64/x86_64-w64-mingw32/include/c++ –enable-shared –enable-static –disable-multilib –enable-languages=c,c++,fortran,lto –enable-libstdcxx-time=yes –enable-threads=posix –enable-libgomp –enable-libatomic –enable-lto –enable-graphite –enable-checking=release –enable-fully-dynamic-string –enable-version-specific-runtime-libs –disable-isl-version-check –disable-libstdcxx-pch –disable-libstdcxx-debug –enable-bootstrap –disable-rpath –disable-win32-registry –disable-nls –disable-werror –disable-symvers –with-gnu-as –with-gnu-ld –with-arch=nocona –with-tune=core2 –with-libiconv –with-system-zlib –with-gmp=/c/mingw530/prerequisites/x86_64-w64-mingw32-static –with-mpfr=/c/mingw530/prerequisites/x86_64-w64-mingw32-static –with-mpc=/c/mingw530/prerequisites/x86_64-w64-mingw32-static –with-isl=/c/mingw530/prerequisites/x86_64-w64-mingw32-static –with-pkgversion=’x86_64-posix-seh-rev0, Built by MinGW-W64 project’ –with-bugurl=http://sourceforge.net/projects/mingw-w64 CFLAGS=’-O2 -pipe -I/c/mingw530/x86_64-530-posix-seh-rt_v4-rev0/mingw64/opt/include -I/c/mingw530/prerequisites/x86_64-zlib-static/include -I/c/mingw530/prerequisites/x86_64-w64-mingw32-static/include’ CXXFLAGS=’-O2 -pipe -I/c/mingw530/x86_64-530-posix-seh-rt_v4-rev0/mingw64/opt/include -I/c/mingw530/prerequisites/x86_64-zlib-static/include -I/c/mingw530/prerequisites/x86_64-w64-mingw32-static/include’ CPPFLAGS= LDFLAGS=’-pipe -L/c/mingw530/x86_64-530-posix-seh-rt_v4-rev0/mingw64/opt/lib -L/c/mingw530/prerequisites/x86_64-zlib-static/lib -L/c/mingw530/prerequisites/x86_64-w64-mingw32-static/lib ‘
Thread model: posix
gcc version 5.3.0 (x86_64-posix-seh-rev0, Built by MinGW-W64 project)”I selected in the project add new toolchanin by Locating it and it detected it ok
When i try to build the project i get this error :
“1>—— Build started: Project: SFunction, Configuration: Debug VisualGDB ——
1>C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\SysprogsPlatform.targets(39,3): warning MSB4011: “C:\Users\xxx\AppData\Local\VisualGDB\FindComponents.props” cannot be imported again. It was already imported at “C:\Users\xxx\Desktop\Study\MATLAB\Matlab_To_C\SFunction\Simple_Function\SFunction\SFunction\SFunction.vcxproj (41,5)”. This is most likely a build authoring error. This subsequent import will be ignored.
1>ue2+k1
1>ue2+k1: Could not find the toolchain com.sysprogs.imported.mingw 5.3.0/7.10.1/r0
1> at ue2.x(RemoteHostSettings c, ToolchainKey a, ToolchainType d, sv b)
1> at e22..ctor(VisualGDBProjectSettings2 b, to e, js1 c, s2 f, sv a, IDELevelProjectInfoForBuilding d)
1> at yf2..ctor(VisualGDBProjectSettings2 a, to c, IDELevelProjectInfoForBuilding d, js1 b)
1> at VisualGDB.MSBuild.BuildHelper..ctor(String vgdbSettingsFile, IDELevelProjectInfoForBuilding info)
1> at Sysprogs.build.tasks.shared.LaunchVisualGDB.Execute()
1>C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\external.targets(5,3): error : Could not find the toolchain com.sysprogs.imported.mingw 5.3.0/7.10.1/r0
1>Done building project “SFunction.vcxproj” — FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========”Attachments:
You must be logged in to view attached files.July 22, 2018 at 18:05 #21429support
It looks like Visual Studio might have cached the old toolchain list. Please try restarting it.
July 28, 2018 at 17:23 #21484b.timofte
ParticipantOk Worked .
Another issue is when i attach to Matlab.exe it takes 20 minutes to load all dlls. Is this a bug in gdb.exe?
This is how part of the log looks …. It goes on for 20 minutes on a core i7 2.8 Ghz … Wtf 🙁
ibrary-loaded,id=”C:\\MATLAB\\bin\\win64\\sl_units.dll”,target-name=”C:\\MATLAB\\bin\\win64\\sl_units.dll”,host-name=”C:\\MATLAB\\bin\\win64\\sl_units.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\cgir_vm.dll”,target-name=”C:\\MATLAB\\bin\\win64\\cgir_vm.dll”,host-name=”C:\\MATLAB\\bin\\win64\\cgir_vm.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\fitools.dll”,target-name=”C:\\MATLAB\\bin\\win64\\fitools.dll”,host-name=”C:\\MATLAB\\bin\\win64\\fitools.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwslexec_simbridge.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_simbridge.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_simbridge.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\m3i.dll”,target-name=”C:\\MATLAB\\bin\\win64\\m3i.dll”,host-name=”C:\\MATLAB\\bin\\win64\\m3i.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwslexec_solver.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_solver.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_solver.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\sltp_mm.dll”,target-name=”C:\\MATLAB\\bin\\win64\\sltp_mm.dll”,host-name=”C:\\MATLAB\\bin\\win64\\sltp_mm.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libemlrt.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libemlrt.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libemlrt.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\shared_code_manager.dll”,target-name=”C:\\MATLAB\\bin\\win64\\shared_code_manager.dll”,host-name=”C:\\MATLAB\\bin\\win64\\shared_code_manager.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\cgir_support.dll”,target-name=”C:\\MATLAB\\bin\\win64\\cgir_support.dll”,host-name=”C:\\MATLAB\\bin\\win64\\cgir_support.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\performance_tracer.dll”,target-name=”C:\\MATLAB\\bin\\win64\\performance_tracer.dll”,host-name=”C:\\MATLAB\\bin\\win64\\performance_tracer.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwslio_core.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwslio_core.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwslio_core.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\gmp.dll”,target-name=”C:\\MATLAB\\bin\\win64\\gmp.dll”,host-name=”C:\\MATLAB\\bin\\win64\\gmp.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwsigstream.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwsigstream.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwsigstream.dll”,symbols-loaded=”0″,thread-group=”i1″=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineWidgetsMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineWidgetsMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineWidgetsMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5QuickMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5QuickMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5QuickMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5WebChannelMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5WebChannelMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5WebChannelMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-unloaded,id=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5QmlMW.dll”,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineCoreMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineCoreMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5WebEngineCoreMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-unloaded,id=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,target-name=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,host-name=”C:\\MATLAB\\bin\\win64\\Qt5OpenGLMW.dll”,thread-group=”i1″
=library-loaded,id=”C:\\WINDOWS\\SYSTEM32\\secur32.dll”,target-name=”C:\\WINDOWS\\SYSTEM32\\secur32.dll”,host-name=”C:\\WINDOWS\\SYSTEM32\\secur32.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\WINDOWS\\SYSTEM32\\usp10.dll”,target-name=”C:\\WINDOWS\\SYSTEM32\\usp10.dll”,host-name=”C:\\WINDOWS\\SYSTEM32\\usp10.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwslexec_parallel.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_parallel.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_parallel.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\mpfr.dll”,target-name=”C:\\MATLAB\\bin\\win64\\mpfr.dll”,host-name=”C:\\MATLAB\\bin\\win64\\mpfr.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwslexec_runtime.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_runtime.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwslexec_runtime.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\sl_unit_repository.dll”,target-name=”C:\\MATLAB\\bin\\win64\\sl_unit_repository.dll”,host-name=”C:\\MATLAB\\bin\\win64\\sl_unit_repository.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwdesuite_kernel_util.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwdesuite_kernel_util.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwdesuite_kernel_util.dll”,symbols-loaded=”0″,thread-group=”i1″
=library-loaded,id=”C:\\MATLAB\\bin\\win64\\libmwmfl_fft.dll”,target-name=”C:\\MATLAB\\bin\\win64\\libmwmfl_fft.dll”,host-name=”C:\\MATLAB\\bin\\win64\\libmwmfl_fft.dll”,symbols-loaded=”0″,thread-group=”i1″…..
July 28, 2018 at 22:13 #21485support
The best way to diagnose this would be to narrow it down to a specific component. Please try attaching to the target process by running gdb directly from command line. Do you observe the same behavior?
If not, please enable the GDB command timing view in the GDB Session window and check if the delay comes after any specific command (you can also enable the creation of detailed gdb logs via Advanced GDB Settings – the created logs will contain timestamps for every line).
