Bug Submission – Possible Feature Improvement.
Sysprogs forums Forums VisualGDB Bug Submission – Possible Feature Improvement.
  • #6782
    dmitryponv
    Good afternoon,
    This is a submission of what is possibly a bug for VisualGDB
    This is for importing projects created with CMake.
    The issue is when CMakeLists.txt is in one directory but the Build directory is not within the same directory as CMakeLists.txt
    For example, setting the MainSourceDirectoryForLocalBuilds source containing CMakeLists.txt to:
        <MainSourceDirectoryForLocalBuilds>D:\svn\Project\source</MainSourceDirectoryForLocalBuilds>
    And BinaryDirectory vs_arm_debug (adjacent to, but not within the source directory)
        <BinaryDirectory>../vs_arm_debug</BinaryDirectory>
    Causes an error running the CMake command:
      VisualGDB: Run "C:\Program Files (x86)\CMake\bin\cmake.exe -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF .. -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake -DCMAKE_MAKE_PROGRAM="C:/SysGCC/raspberry/bin/make.exe"" in directory "D:\svn\Project\source/../vs_arm_debug/" on local computer
    1>EXEC : CMake error : The source directory "D:/svn/Project" does not appear to contain CMakeLists.txt.
    The Problem is, VisualGDB is running CMake from the Build Directory,
    What the command really should be is:
    Run "C:\Program Files (x86)\CMake\bin\cmake.exe -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF .. -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake -DCMAKE_MAKE_PROGRAM="C:/SysGCC/raspberry/bin/make.exe" ../source"
    The ../source added at the end will cause CMake to switch back to the source directory with CMakeLists.txt while creating the MakeFile in the vs_arm_debug directory.
    Of course, the real name of the directory should be parsed from User’s input.
    Please comment if there is a workaround for running a custom cmake command
    Thank you,
    • This topic was modified 11 years, 1 month ago by dmitryponv.
    #6786
    dmitryponv
    To Add to this Feature Request/Bug
    The CMake command is mostly hard-coded, and when adding Arguments, they are added to the beginning of the command, not the end, so adding ../source/ makes it
    Run "C:\Program Files (x86)\CMake\bin\cmake.exe ../source -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF .. -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake -DCMAKE_MAKE_PROGRAM="C:/SysGCC/raspberry/bin/make.exe""
    Which is evidently pretty useless, because it tries to run everything from the source folder. Instead
    Another problem is the flags are hard-coded and impossible to change.
    For example: the -DCMAKE_TOOLCHAIN_FILE=toolchain-Debug.cmake flag remains the same in the command line, even when I remove toolchain-Debug.cmake from CMake Files in the Solution Explorer and add my armtoolchain-vs.cmake
    It would be good to be able to edit the CMake.exe command line entirely
    Thank you,
    #6787
    dmitryponv
    Ok I figured out a way around this if anybody is havingthe same problem:
    Simply, create a cmake.bat file next to cmake.exe in C:\Program Files (x86)\CMake\bin
    Into it, enter (this is from the above example)
    cmake -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_COLOR_MAKEFILE=OFF -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_TOOLCHAIN_FILE="../armtoolchain-vs.cmake" -DCMAKE_MAKE_PROGRAM="C:/SysGCC/raspberry/bin/make.exe" ../source
    echo
    Then in VisualGDB properties enter “C:\Program Files (x86)\CMake\bin\cmake.bat” for Command Line instead of cmake.txt
    This will cause the hard-coded arguments to be appended to the echo command instead of the cmake.exe command
    However, entering echo into the arguments list does not work the same way,
    I am looking for something line a ENTER or CR to force a carriage return before the echo command directly in the Arguments list, to make this a bit easier to set up.
    Thank you,
    • This reply was modified 11 years, 1 month ago by dmitryponv.
    #6804
    Thanks for reporting this, we have fixed the problem with the relative paths in VisualGDB 5.0R2. You can download it here: http://visualgdb.com/download/
    We have also added an option (currently unsupported via GUI) to disable the use of toolchain files. Please change any setting in VisualGDB Project Propreties, save the settings, open the .vgdbsettings file in a text editor and modify the DisableToolchainFile field.
