Sysprogs forums › Forums › VisualGDB › autocomplete/intellisense problem * SOLVED*
- This topic has 10 replies, 2 voices, and was last updated 12 years, 2 months ago by
allard.
June 23, 2014 at 01:05 #855
allard
ParticipantAutocomplete doesn’t work in some cases. Here’s an example:
#include
using namespace std;
struct DB_T{
int key;
int prop1;
} DB[300];int main(int argc, char *argv[])
DB[1].prop1 = 5;
return 0;
}Now this compiles perfectly. However when I type that DB[1]. then it doesnt show “prop1” in a dropdown box (it doesnt show any dropbox at all), it just does nothing. This is very irritating cause now I have to know all DB properties out of my head. If you do this on a native windows machine (so not using visualGDB), it does show that of course. Any ideas ?
BTW running visual GDB linux edition 4.1 and VS 2012 11.0.50727.1
June 23, 2014 at 01:21 #3250allard
ParticipantWeird thing is, if I save it, close the project, reopen it then it suddenly works !?! What’s happening here ? If I then changed the name of the DB like into PDB en then type PDB[1]. it doesnt autocomplete again, then i have to save and restart it in order to work …
June 23, 2014 at 01:28 #3251allard
ParticipantBut it gets even weirder: in a program of mine, it does work from within a specific object/method and doesn’t autocomplete from within another object/method (the code compiles perfectly of course when I manually specify the attribute like DB[1].key, so that’s not the problem)
June 27, 2014 at 23:31 #3242support
What VS version are you using? Are you building a MinGW or a Linux project? Does the Errors window contain any IntelliSense-specific errors?
July 14, 2014 at 18:17 #3243allard
Participant@bazis wrote:
HI,
Like stated in my post, I use VS 2012 11.0.50727.1. I don’t see any intellisense errors at all. Thanks.
July 15, 2014 at 18:00 #3244allard
ParticipantBTW, my project is a linux one
July 16, 2014 at 22:37 #3245support
KeymasterVisualGDB reuses the Visual Studio IntelliSense engine (it configures it by providing GCC-specific definitions and include paths). Sometimes, the Visual Studio IntelliSense engine produces strange results. We are currently working on a new engine that will handle the GCC-specific code natively. As a temporary workaround before we have released it you can try commenting out arbitrary include directives to see which of them breaks IntelliSense.
July 17, 2014 at 16:58 #3246allard
Ok good to hear you’re working on it. Otherwise I just LOVE this plugin, so really hoping you can get this working ! Good luck !
July 22, 2014 at 15:49 #3247allard
ParticipantBTW, any timeline on your Intellisense replacement engine ?
July 22, 2014 at 16:56 #3248allard
ParticipantBTW, It’s most probably related: every time that I open my project and change for the first time something, I get a VS STudio error: “An exception has been encountered. This may be caused by an extension”. And then it refers to activitylog.xml. When I open that log it says:
System.InvalidCastException: Unable to cast COM object of type ‘System.__ComObject’ to interface type ‘Microsoft.VisualStudio.Editor.Implementation.IVsTextStreamEvents_Private’. This operation failed because the QueryInterface call on the COM component for the interface with IID ‘{96FC7D44-BCDD-4F00-AE4D-07E26B2C0E52}’ failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)). at System.StubHelpers.StubHelpers.GetCOMIPFromRCW(Object objSrc, IntPtr pCPCMD, IntPtr& ppTarget, Boolean& pfNeedsRelease) at Microsoft.VisualStudio.Editor.Implementation.IVsTextStreamEvents_Private.OnChangeStreamText(Int32 iPos, Int32 iOldLen, Int32 iNewLen, Int32 fLast) at Microsoft.VisualStudio.Editor.Implementation.VsTextBufferAdapter.OnTextBufferChanged(Object sender, TextContentChangedEventArgs e) at Microsoft.VisualStudio.Text.Utilities.GuardedOperations.RaiseEvent[TArgs](Object sender, EventHandler`1 eventHandlers, TArgs args)
July 22, 2014 at 17:06 #3249allard
ParticipantIt seems I solved it !!!
Solution:Using regedit look at the following key:
On 32-Bit Windows: [HKEY_CLASSES_ROOTCLSID{73B7DC00-F498-4ABD-AB79-D07AFD52F395}InProcServer32]
On 64-Bit Windows: [HKEY_CLASSES_ROOTWow6432NodeCLSID{73B7DC00-F498-4ABD-AB79-D07AFD52F395}InProcServer32]The “(Default)” value should be one of the following:
On 32-Bit Windows: “C:Program FilesCommon FilesMicrosoft SharedMSEnvTextMgrP.dll”
On 64-Bit Windows: “C:Program Files (x86)Common FilesMicrosoft SharedMSEnvTextMgrP.dll”No more VS exception messages, and autocomplete now seems to work fine !! Found this solution at: http://connect.microsoft.com/VisualStudio/feedback/details/546369/
