Sysprogs forums › Forums › VisualGDB › [AVR targets] Atmel Studio GDB server
- This topic has 5 replies, 2 voices, and was last updated 8 years ago by
March 13, 2018 at 17:26 #20383
gchapman
Participanthttps://www.avrfreaks.net/forum/making-gdb-attach-gdbserver-instead-launching#comment-2420641
… (although atbackend can act as a gdb server if someone wants to use it with a gdb-enabled frontend)
Reason: atbackend.exe as an alternative to AVaRICE.
The next post in that thread shows partial integration via MIEngine.
https://github.com/Microsoft/MIEngine
This topic was modified 8 years ago by
support. Reason: updated title to mention AVR
March 13, 2018 at 18:58 #20385support
Sure, you can configure VisualGDB to use the Atmel gdb server as well (as well as any other IDE with GDB support), although it won’t provide many advanced features included with our OpenOCD fork (e.g. automatically resolving driver issues, profiling, monitoring memory in the background), so we normally advise getting a debug probe supported by OpenOCD and using it instead.
March 14, 2018 at 19:24 #20404gchapman
ParticipantThank you for I was not aware of the OpenOCD advantages.
The intention of my post was in the context of AVR and support for recently announced AVR (tinyAVR 1-series, tinyAVR 0-series, megaAVR 0-series)
gnutoolchains.com AVR is from FSF instead of from Microchip.
AVaRICE is FOSS.
My assumption is y’all’s goal is to start with FOSS then extend that if necessary.
Edit:
FSF AVR GCC 8 adds tinyAVR 1-series :
https://gcc.gnu.org/gcc-8/changes.html
ATtiny212, ATtiny214, ATtiny412, ATtiny414, ATtiny416, ATtiny417, ATtiny814, ATtiny816, ATtiny817, ATtiny1614, ATtiny1616, ATtiny1617, ATtiny3214, ATtiny3216, ATtiny3217
This reply was modified 8 years ago by
gchapman.
March 14, 2018 at 19:46 #20406support
No problem, thanks for sharing this. For AVR devices using the Atmel gdb server could be indeed better than the open source AVaRICE tool.
March 14, 2018 at 20:07 #20408gchapman
ParticipantThank you for extending the thread’s title.
For VisualGDB, is there a preference for AVaRICE, or, is it any AVR GDB server?
Reason:
Risk reduction for eventual Atmel Studio EOL.
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs
March 15, 2018 at 04:27 #20417support
AVaRICE does a pretty good job for an open-source tool, so we do recommend using it. If the license of the Atmel GDB server allows using it with non-Atmel products like VisualGDB, it could be a good alternative to AVaRICE, however it might be tough troubleshooting it as it’s likely not designed to be used outside Atmel Studio.
