Atmel ARM Toolchain in VisualGDB
Sysprogs forums Forums VisualGDB Atmel ARM Toolchain in VisualGDB
  • #30229
    fuji
    I’m trying to use the Atmel ARM 6.3.1.508 toolchain in a bare metal embedded project with C++ 11 and C files. ARM CMSIS 5.4.0, Atmel SAMD21_DFP. Builds, loads and runs with GnuWin32 make.
    I created a project with the embedded wizard using MSBuild.
    I added the Atmel toolchain using the “Select a third party toolchain by locating gdb.exe” option and selected the gdb.exe of the Atmel ARM toolchain.
    I setup the flags, linker file and imported the sources.
    I get the following error when I build
    Error Could not find the toolchain d0e7b5fb-2412-4baf-9352-bf72733e7739 6.3.1/(Atmel/r0 TestM0 C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\gcc.targets 310
    How do I proceed?
    VisualGDB version 5.5R4 build 3920
    #30230
    This looks like an issue caused by the toolchain cache. Please try restarting Visual Studio, it should fix the issue.
