I’m seeing “'ansi+tabs': unknown terminal type” when I try to build to a CentOS 7 Docker container using VisualGDB. (I have not had this problem when building to an Ubuntu 21 container.)
Also, if I go into the SSH Connection Manager and then click “Test Connection,” I’m informed that the connection was made, but that “'pwd' returned an unexpected reply.”
If I open a console to my Docker container from the SSH Connection Manager, I don’t see anything untoward. It connects just fine, and a pwd command shows my present working directory as expected. However, whenever I enter a cd command to change directory, I get the output “'ansi+tabs': unknown terminal type” just before the directory change is effected.
I’d rather not set my project to ignore file transfer errors. How do I go about addressing this problem?
