I need to use Alt+ in a Linux terminal session. Unfortunately, SmartTTY interpets Alt key as menu request and does not pass it to Linux session.
How can I configure SmartTTY to pass Alt+ to SSH session?
Thanks for your answser. What bugs me most about mtputty is that it breaks the alt+tab cycling in windows. Well, looks like I’ll stick to mputty for a while longer.
Just tried smarttty – and had same issue (switching between channels in irssi using Alt doesn’t work), and atm this issue makes smarttty unusable for me.
SSH users usually don’t need to access the menu while they use terminal, so maybe add an option to hide it (just like settings dialog is ‘hidden’ in putty) or to just disable the Alt hotkey ?
