Advanced CMake Project – RSP File Deleted on linker success
Sysprogs forums › Forums › VisualGDB › Advanced CMake Project – RSP File Deleted on linker success
  • #32231
    JFerraris
    Hello!
    I am not exactly sure whether this is a bug or a known feature, but the generated rsp file (linker arguments) in a CMake project gets automatically deleted on a successful build. The only way to get it to stay (that I know of) is to cause a linker error purposely which keeps it lying in the build directory, but otherwise it is deleted on successful build.I looked through almost all the preferences and VisualGDB properties that I could to see if there was any settings to turn off the deletion but I could not find anything.
    It would be greatly appreciated if you could either add an option to keep this file, or to even just never remove it because I don’t see any need for it to be removed.
    Appreciate your time! Thank you.
    #32232
    This is handled directly by CMake, rather than VisualGDB. Feel free to browse through CMake source code to see if there is a way to modify this behavior.
    #32237
    JFerraris
    Thank you for pointing me in the right direction! I found this link that explained it all, ninja was the culprit here. To get ninja to not delete the rsp file I used the -d keeprsp switch in the Ninja Options in VisualGDB Properties:
    https://gitlab.kitware.com/cmake/cmake/-/issues/20277
    Thank you for the help!
