Add link timestamp to program
Sysprogs forums › Forums › VisualGDB › Add link timestamp to program
  • #32493
    andrew
    I’m trying to use the Project Properties’ “Linker -> Command Line -> Additional options” setting to add a build-timestamp to the program. It’s a beaglebone linux project being cross-compiled on Windows 10.
    Here is what I’ve tried:
    -Wl,--defsym,MVV2_TIMESTAMP="$(shell date /t)"
    -Wl,--defsym,MVV2_TIMESTAMP="$(shell date +s%)"
    -Wl,--defsym,MVV2_TIMESTAMP="$(date /t)"
    -Wl,--defsym,MVV2_TIMESTAMP="'date /t'"
    When I try to build the program using any of the above settings I get ld.exe:--defsym:0: syntax error
    What is the correct syntax? How can I see the exact command that VisualGDB is trying to execute?
    #32494
    It looks like your technical support period has expired. We would be happy to help you, however we would kindly ask you to renew your technical support on the following page first: https://sysprogs.com/splm/mykey​
