wrong memory size on STM32H723ZG
Sysprogs forums Forums VisualGDB wrong memory size on STM32H723ZG
  • #36101
    intector
    The memory sizes in the device selection during the creation of a new embedded project are wrong for the STM32H723ZG MCU. I’ve attached a screenshot.
    Also, the linker script contains wrong memory settings.
    here is what VisualGDB produces:
    MEMORY
    FLASH (RX) : ORIGIN = 0x08000000, LENGTH = 1M
    SRAM (RWX) : ORIGIN = 0x24000000, LENGTH = 128K
    DTCMRAM (RWX) : ORIGIN = 0x20000000, LENGTH = 128K
    RAM_D2 (RWX) : ORIGIN = 0x30000000, LENGTH = 32K
    RAM_D3 (RWX) : ORIGIN = 0x38000000, LENGTH = 16K
    ITCMRAM (RWX) : ORIGIN = 0x00000000, LENGTH = 64K
    and here is what it should be:
    MEMORY
    ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
    DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
    FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
    RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 320K
    RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 32K
    RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 16K
    What is the problem with the wrong memory definitions?
    #36103
    The memory definitions are automatically parsed from the device definitions inside the original SDKs, and sometimes they don’t match the datasheets. Normally, ST fixes this in the next SDK release. Until then, patching the linker script manually should be a reasonable workaround.
    #36110
    intector
    Thank you for the fast answer. I’ve done this before, and I was just wondering if I could change the definitions myself.
    #36117
    You can just patch the linker script file under %LOCALAPPDATA%\VisualGDB\EmbeddedBSPs.
    If you want to fix it for multiple devices, you can try regenerating the entire BSP from the STM32 SDKs using our BSP generator. However, it involves some manual setup (e.g. downloading STM32CubeMX) and will download huge SDK packages from ST.
