WinCDEmu crashes
Sysprogs forums › Forums › WinCDEmu › WinCDEmu crashes
  • #392
    RedTulip
    The first time I installed WinCDEmu 3.6, it was OK.
    I uninstalled it and installed it again after a while. Just before it said “Installation Complete.”, a window popped up saying “WinCDEmu mounter has stopped working”. I pressed Close the program.
    Then, whenever I try to mount a file (mdf or mds – even iso. I think this applies to all files, even uif.), the same window pops up, saying WinCDEmu stopped working, again.
    I try to uninstall it and reinstall, but nothing happens. The same problem.
    Please help.
    #2016
    Same problem. I’ll attach my error log here (the one provided by Windows). Hope it will help to resolve the issue. I had to translate it into English by myself so excuse me if the “official” translation is different.
    Problem signature:
    Problem event name:	APPCRASH
    Application name:	vmnt.exe
    Application version:	3.6.0.0
    Application timestamp:	4e4026fe
    Faulty module name:	vmnt.exe
    Faulty module version:	3.6.0.0
    Faulty module timestamp:	4e4026fe
    Exception code:	c0000005
    Exception offset:	0001e742
    OS version:	6.1.7601.2.1.0.256.48
    Language code:	1049 (comment: this is Russian)
    Additional data 1:	0a9e
    Additional data 2:	0a9e372d3b4ad19135b953a78882e789
    Additional data 3:	0a9e
    Additional data 4:	0a9e372d3b4ad19135b953a78882e789
    #2017
    I had the same/similar problem on Win7 (simulated with qemu).
    Everytime I tryed to mount an iso image WinCDEmu crashed. I removed it and reinstalled it to post the Error here but now it works 😀
    Small, simple and it does exactly what should do and nothing else. Thanks for this great tool.
    Al
    #2018
    It was crashing for me too on windows 7. I had to uninstall and then reinstall into a different directory and now it works! The original install left a context menu dll that wasn’t uninstalled though.
    #2019
    WinCDEmu was also crashing (silently – open iso with wincdemu and the process shows up for a second along with werfault.exe then it disappeared or sometimes stayed around forever eating one core worth of cpu) for me on win 7 and uninstalling and reinstalling in a different directory fixed it. I had already uninstalled/reinstalled several times and nothing worked until I clicked the checkbox to change settings during install and changed the installation directory. I had winzip installed which had ISOs associated with it, so I was initially thinking that was the problem. It works now, so I’m happy. Thanks for this program! I’ve wondered for years why windows never allowed mounting ISOs natively, oh well.
    #2021
    What I noticed is that after you mount and unmount/eject more than 3 disc images (no matter what file format, track size, etc), it crashes after that. I think if you reinstall it or restart the computer it fixes it, but I would much rather find the issue than reinstall every time I wanted to mount a new image.
    #2020
    @albertstien3329 wrote:
    I have a little issue since I updated my visualGDB : every time I launch a debugging session on Android, a logcat window appears in Visual Studio, but since a lot of information are logged, it just freeze Visual Studio and make it just unusable…
    Is there a way to remove the poping of this window every time I launch de debugger?
    Thanks!
    That should be posted either in another thread or contact support directly. This thread is about WinCDEmu. Just saying. 😀
    #2022
    Hi Thanks!!! Works Perfectly Just had to choose different directory during installation
    #7859
    hnoor0055
    ________________-
    NOOR
    • This reply was modified 10 years, 6 months ago by hnoor0055.
