WinCDEmu 3.6 Causing Explorer.EXE To Stop Working?
Sysprogs forums Forums WinCDEmu WinCDEmu 3.6 Causing Explorer.EXE To Stop Working?
  • #457
    goodjohnjr
    I am using WinCDEmu 3.6 and I have been having a problem where randomly throughout the day Explorer.exe will stop working and so it has to refresh, and my desktop/icons/et cetera refresh as well.
    After days of trying to figure out what was causing the problem, I found that WinCDEmuContextMenu.dll_unloaded, version: 0.0.0.0, was probably the problem according to the Windows Event Viewer; and so I un-installed WinCDEmu and the problem stopped, almost two days later I decided to download & install WinCDEmu 3.6 again; and the problem has once again returned.
    Here is an example of one of the Windows Event Logs that I saved:
    I just wanted to report this, I am not sure if this is a glitch/bug or if something else is the problem.
    #2135
    I get this whenever I try to use “run as different user” in W7 x86
    #2136
    goodjohnjr
    I uninstalled the regular WinCDEmu and I use the portable version now because I do not have this problem with it; thank you for letting me know that I was not the only person with this problem Karl, I had forgotten that I had even posted this since no one has responded until you, and I posted this over a month ago. πŸ˜€
    #2137
    I forgot to mention that I only have one user on my computer, and I still have this problem; but the portable version has not had this problem yet.
    #2138
    The portable version don’t have this problem because don’t have the extension association o new entry in contex menu ( WinCDEmuContextMenu.dll )
    That’s all.
