Sysprogs forums › Forums › VisualGDB › what is wrong of the ESP32 examples build error?
- This topic has 1 reply, 2 voices, and was last updated 7 years, 11 months ago by
April 26, 2018 at 08:14 #20815
march_seven
ParticipantHi all
when i using visual GDB for build the example of ESP32 , there is a error happened
i have not config a debug method ,just set as COM3 as the raw port~~~
VisualGDB is licensed to Company (site license)
c:\SysGCC\esp32\bin\xtensa-esp32-msvs-gdb.exe –interpreter mi F:\Embedded\esp32\EmbeddedProject1\VisualGDB\Debug\EmbeddedProject1
-gdb-version
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 7.10\n”
~”Copyright (C) 2015 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-pc-mingw32 –target=xtensa-esp32-elf\”.\nType \”show configuration\” for configuration details.”
This GDB was configured as “–host=i686-pc-mingw32 –target=xtensa-esp32-elf”.
~”For help, type \”help\”.\n”
~”Reading symbols from F:\\Embedded\\esp32\\EmbeddedProject1\\VisualGDB\\Debug\\EmbeddedProject1…”
~”done.\n”
^done
-list-features
-gdb-set print demangle off
^done
-break-insert -f main
&”Function \”main\” not defined.\n”
-break-delete 1
^done
esptool.py v2.0
Traceback (most recent call last):
File “/esp32-bsp/esp-idf/components/esptool_py/esptool/esptool.py”, line 2405, in <module>
_main()
File “/esp32-bsp/esp-idf/components/esptool_py/esptool/esptool.py”, line 2398, in _main
main()
File “/esp32-bsp/esp-idf/components/esptool_py/esptool/esptool.py”, line 2121, in main
esp = ESPLoader.detect_chip(args.port, initial_baud, args.before)
File “/esp32-bsp/esp-idf/components/esptool_py/esptool/esptool.py”, line 201, in detect_chip
detect_port = ESPLoader(port, baud)
File “/esp32-bsp/esp-idf/components/esptool_py/esptool/esptool.py”, line 175, in __init__
self._port = serial.serial_for_url(port)
File “/usr/lib/python2.7/site-packages/serial/__init__.py”, line 88, in serial_for_url
instance.open()
File “/usr/lib/python2.7/site-packages/serial/serialposix.py”, line 268, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyS2: [Errno 13] Permission denied: ‘/dev/ttyS2’
-target-disconnect
^error,msg=”You can’t do that when your target is `exec'”
-gdb-exit
^exitAttachments:
You must be logged in to view attached files.April 26, 2018 at 22:39 #20823support
Please let us know the email associated with your license key so that we could check your support status.
