What files should go into a repo?
Sysprogs forums › Forums › VisualGDB › What files should go into a repo?
  • #9190
    sidprice
    In addition to the source, headers, and project files of VS what additional folders/files should be checked into a repo when working with a separate Linux build server and separate target?
    Sid
    #9192
    You definitely need to check in the .vgdbsettings files as they contain VisualGDB-specific settings. If you are using Make, CMake or QMake, you also need to check in the main project file and the configuration files from that build systems.
