Watch window display format
Sysprogs forums › Forums › VisualGDB › Watch window display format
  • #9518
    sidprice
    It seems VisualGDB does not display an array of “unsigned char” in hex correctly, I see values like “0x-1” when it should be 0x09.
    I hope this link to capture works:
    https://1drv.ms/i/s!AuP9dQYeglUkgotbQuDZXQKuEVIB0A
    Sid
    #9523
    sidprice
    I think I figured this out. I added “set output-radix 16” to the GDB startup parameters and now my arrays display as hex numbers.
    However, I would expect that if I used the VS context menu to select hex display then VisualGDB should indeed display my arrays as hex.
    Also, is there a way to have the mixed hex and ASCII display as VS normally does for unsigned and signed chars?
    Sid
    #9532
    Are you using the latest version 5.2? We had a similar bug in v5.1 and it got fixed in v5.2.
    If yes, could you please attach your gdb session log so that we could check what is going on?
