Sysprogs forums › Forums › VisualGDB › Warning: could not set a breakpoint on main. 'Step into new instance'
- This topic has 3 replies, 2 voices, and was last updated 7 years, 8 months ago by
March 18, 2018 at 22:16 #20461
xox
ParticipantIntro:
I have checked out multiple posts to this topic already, but I could not find the solution that is why I am writing now.
Problem:
My break points stay unresolved.
Setup:I am using the cross compiling setting: That means I am building on my Win10 with Visual Studio 17 and the deploy the program on the pi model 3
Settings:
CFLAGS/CXXFLAGS: -std=gnu++14 -ggdb -ffunction-sections -O0 -mfloat-abi=hard
GDB Output:
-gdb-version
=thread-group-added,id=”i1″
GNU gdb (Raspbian 7.12-6) 7.12.0.20161007-git
Copyright (C) 2016 Free Software Foundation, Inc.
This GDB was configured as “–host=i686-w64-mingw32 –target=arm-linux-gnueabihf”.
For help, type “help”.
&”LandshipsPlusPlus: No such file or directory.\n”
OK
-list-features
No symbol table is loaded. Use the “file” command.
-gdb-set print demangle off
OK
-break-insert -f main
&”No symbol table is loaded. Use the \”file\” command.\n”
-break-delete 1
OK
-gdb-set solib-search-path I:/Y2017C-Y1-PR-Team07/Code/LandshipsPlusPlus/CrossCompiling
OK
-gdb-show sysroot
^done,value=”a:\\sysgcc\\raspberry\\arm-linux-gnueabihf\\sysroot”
-gdb-show debug-file-directory
^done,value=”c:\\q\\gnu\\raspberry\\out\\lib\\debug”
-gdb-set debug-file-directory a:/sysgcc/raspberry/arm-linux-gnueabihf/sysroot/usr/lib/debug
OK
-target-select remote 192.168.137.122:2000
=thread-group-started,id=”i1″,pid=”3127″
&”warning: Could not load vsyscall page because no executable was specified\n”
0x76fce9e0 in ?? ()
*stopped,frame={addr=”0x76fce9e0″,func=”??”,args=[]},thread-id=”1″,stopped-threads=”all”,core=”2″
^connected
info shared
&”info shared\n”
No shared libraries loaded at this time.
OK
info target
&”info target\n”
Remote serial target in gdb-specific protocol:
Debugging a target over a serial line.
OK
-break-insert -f LandshipsPlusPlus.cpp:75
^done,bkpt={number=”2″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”<PENDING>”,pending=”LandshipsPlusPlus.cpp:75″,times=”0″,original-location=”LandshipsPlusPlus.cpp:75″}
-file-list-exec-source-files
^done,files=[]
-break-after 2 0
OK
All created breakpoints are pending. Setting a breakpoint at main()…
^done,bkpt={number=”3″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”<PENDING>”,pending=”main”,times=”0″,original-location=”main”}
-exec-continue
^running
*running,thread-id=”all”info sources
info sources
&”info sources\n”
&”No symbol table is loaded. Use the \”file\” command.\n”Resolve Breakpoints
The current loaded GDB symbols have no record of any file called […]Additional Information
I have separated project (new) there it works everything fine. This project was originally a project which were building on the pi.
I hope you can help me or give me the right advice. Thank you very much.
March 19, 2018 at 00:14 #20462support
Looks like your project is built without debugging symbols. Please ensure you specify the “-ggdb” flag in the CFLAGS/CXXFLAGS.
March 19, 2018 at 09:47 #20466xox
ParticipantHey thanks for the quick answer but as I mentioned in my initial post:
Intro:
Problem:
Settings:
I have this flag there as u see here: CFLAGS/CXXFLAGS: -std=gnu++14 -ggdb –
March 19, 2018 at 19:01 #20472support
Sorry for the confusion. If the -ggdb flag is present, the debug symbols could be accidentally removed from the final executable by using the ‘strip’ command. We have published a detailed tutorial showing how to diagnose symbol-related problems here: https://visualgdb.com/tutorials/linux/symbols/
Please feel free to follow it and let us know if you have any questions. If you are using a cross-compiler, the equivalent of the objdump tool is arm-linux-gnueabihf-objdump.exe (you would need to search its output for “.debug_xxx” sections manually as grep is not available on Windows unless you have Cygwin installed).
