Sysprogs forums › Forums › VisualGDB › VS Error after finished debugging
- This topic has 5 replies, 2 voices, and was last updated 12 years, 2 months ago by
kbzowski.
January 26, 2014 at 17:40 #736
kbzowski
ParticipantI have started getting strange error each time when I finished debugging my programs using VisualGDB (see attached image)
It occurs only in VisualGDB projects – old and new one.If I think carefully I believed it has started after refreshing of sources caches.
January 27, 2014 at 06:22 #2932ket
That looks strange. Could you please give us the dump file?
When this error happens, go to Task Manager and right-click on the Visual Studio process and choose “Create Dump File”.
If the file is huge, then you can use a service like Dropbox.January 27, 2014 at 12:18 #2933January 29, 2014 at 04:09 #2931ket
Based on the call stack below, the error seems to be thrown by the Intel OpenCL SDK dll (icldbgcfg.dll). The error does not seem to be related to VisualGDB at all, as VisualGDB is not mentioned in the entire call stack and as it seems to be icldbgcfg.dll trying to delete its own registry keys. Also, as there is no source available for icldbgcfg.dll, we cannot look into its functions. As such you may want to contact Intel OpenCL SDK support for help about the error.
[Managed to Native Transition] > System.Windows.Forms.dll!System.Windows.Forms.MessageBox.ShowCore(System.Windows.Forms.IWin32Window owner, string text, string caption, System.Windows.Forms.MessageBoxButtons buttons, System.Windows.Forms.MessageBoxIcon icon, System.Windows.Forms.MessageBoxDefaultButton defaultButton, System.Windows.Forms.MessageBoxOptions options, bool showHelp) Unknown
icldbgcfg.dll!Intel.OpenCL.Tools.RegistryHelper.Delete(uint PID) Unknown
icldbgeng.dll!Intel.OpenCL.Tools.OCLDebugEnginePackage.Microsoft.VisualStudio.Debugger.Interop.IDebugEventCallback2.Event(Microsoft.VisualStudio.Debugger.Interop.IDebugEngine2 pEngine, Microsoft.VisualStudio.Debugger.Interop.IDebugProcess2 pProcess, Microsoft.VisualStudio.Debugger.Interop.IDebugProgram2 pProgram, Microsoft.VisualStudio.Debugger.Interop.IDebugThread2 pThread, Microsoft.VisualStudio.Debugger.Interop.IDebugEvent2 pEvent, ref System.Guid riidEvent, uint dwAttrib) Unknown
[Native to Managed Transition]
Microsoft.VisualStudio.Shell.11.0.dll!Microsoft.Internal.VisualStudio.PlatformUI.DataSource.Invoke(string verb, object pvaIn, out object pvaOut) Unknown
Microsoft.VisualStudio.Shell.UI.Internal.dll!Microsoft.VisualStudio.PlatformUI.VsCommand.Execute(object parameter) Unknown
PresentationFramework.dll!MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(System.Windows.Input.ICommandSource commandSource, bool userInitiated) Unknown
PresentationFramework.dll!System.Windows.Controls.Primitives.ButtonBase.OnClick() Unknown
PresentationFramework.dll!System.Windows.Controls.Button.OnClick() Unknown
PresentationFramework.dll!System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(System.Windows.Input.MouseButtonEventArgs e) Unknown
PresentationCore.dll!System.Windows.UIElement.OnMouseLeftButtonUpThunk(object sender, System.Windows.Input.MouseButtonEventArgs e) Unknown
PresentationCore.dll!System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(System.Delegate genericHandler, object genericTarget) Unknown
PresentationCore.dll!System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate handler, object target) Unknown
PresentationCore.dll!System.Windows.RoutedEventHandlerInfo.InvokeHandler(object target, System.Windows.RoutedEventArgs routedEventArgs) Unknown
PresentationCore.dll!System.Windows.EventRoute.InvokeHandlersImpl(object source, System.Windows.RoutedEventArgs args, bool reRaised) Unknown
PresentationCore.dll!System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject sender, System.Windows.RoutedEventArgs args, System.Windows.RoutedEvent newEvent) Unknown
PresentationCore.dll!System.Windows.UIElement.OnMouseUpThunk(object sender, System.Windows.Input.MouseButtonEventArgs e) Unknown
PresentationCore.dll!System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject sender, System.Windows.RoutedEventArgs args) Unknown
PresentationCore.dll!System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs args) Unknown
PresentationCore.dll!System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs args, bool trusted) Unknown
PresentationCore.dll!System.Windows.Input.InputManager.ProcessStagingArea() Unknown
PresentationCore.dll!System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs input) Unknown
PresentationCore.dll!System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport inputReport) Unknown
PresentationCore.dll!System.Windows.Interop.HwndMouseInputProvider.ReportInput(System.IntPtr hwnd, System.Windows.Input.InputMode mode, int timestamp, System.Windows.Input.RawMouseActions actions, int x, int y, int wheel) Unknown
PresentationCore.dll!System.Windows.Interop.HwndMouseInputProvider.FilterMessage(System.IntPtr hwnd, MS.Internal.Interop.WindowMessage msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) Unknown
PresentationCore.dll!System.Windows.Interop.HwndSource.InputFilterMessage(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) Unknown
WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) Unknown
WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o) Unknown
WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) Unknown
WindowsBase.dll!MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(object source, System.Delegate method, object args, int numArgs, System.Delegate catchHandler) Unknown
WindowsBase.dll!System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs) Unknown
WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam) Unknown
[Native to Managed Transition]January 29, 2014 at 07:15 #2929kbzowski
ParticipantWell it is unfortunate case that error shows only with VisualGDB solutions. I have checked almost all solution types available in VS, and only after debugging VisualGDB that error appears. Sorry for the inconvenience. I will submit bug to their support.
Thank you for your help and your time.
January 29, 2014 at 20:51 #2930ket
The error can very well be triggered only for VisualGDB projects. Their tool could likely be assuming something about debug sessions that only holds for Windows or standard Visual Studio project debug sessions. Then at the end of the debug session their assumption does not hold and the error is not silently handled. Nevertheless, this is not something we can fix on our side.
