Sysprogs forums › Forums › VisualKernel › VisualKernel not listed as option under Project Templates
- This topic has 7 replies, 2 voices, and was last updated 7 years, 8 months ago by
June 25, 2018 at 01:43 #21181
andrewtheart
ParticipantVisualKernel not listed as option under Project Templates
After installing the latest version of VisualKernel, in Visual Studio 2017 Enterprise, VisualKernel is not listed as an available option.
I was following the instructions here: https://sysprogs.com/VisualKernel/tutorials/kernel/
June 25, 2018 at 04:04 #21182support
This might be caused by corrupt VS package cache. Please try following the instructions on the following page: http://visualgdb.com/support/loadfail/
Please note that the instructions are for VisualGDB; the only difference for VisualKernel would be the package name.
July 4, 2018 at 02:52 #21245andrewtheart
ParticipantSorry, that did not resolve the issue. I uninstalled one and it is still not showing up.
It shows up correctly in Visual Studio 2015.
July 4, 2018 at 03:43 #21246support
Thanks for the update. Could you please also check if the files/registry values mentioned in steps 7 and 8 are present (replace VisualGDB with VisualKernel in all names)?
July 23, 2018 at 01:46 #21431andrewtheart
ParticipantYes, but it is not as much of a concern to me since I can launch it from VS 2015.
I am getting another error when I am building the kernel.
See sequence of error messages: https://imgur.com/a/lH8wX3M
Error text:
VisualKernel version: 3.0.2.2166
System.Exception: Cannot load LinuxKernelDebugHelper.ko
at mb1.c.b(f2 b, xx1 a)
at mb1.c.l(f2 a)
at VisualGDB.Common_GUI.WPF.ItemizedProgressWindow.<>c__DisplayClass1_0`1.<RunAction>b__0()July 23, 2018 at 20:31 #21452support
Please try clicking the round expander button in the progress window and then check for the build error messages (or use View->Other Windows->VisualKernel Diagnostics Console).
Most likely your kernel is missing some of the configuration options required for the optimized module handling logic.
July 24, 2018 at 12:17 #21464andrewtheart
ParticipantConfiguring KernelDebugHelper module.
Checking layout of ‘struct module’…
make: Entering directory ‘/usr/src/linux-source-4.15.0/linux-source-4.15.0’
CC [M] /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/AppendableBuffer.o
CC [M] /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.o
In file included from /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/AppendableBuffer.c:3:0:
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/AppendableBuffer.h:14:13: warning: ‘ResetAppendableBuffer’ defined but not used [-Wunused-function]
static void ResetAppendableBuffer(AppendableBuffer *pBuffer)
In file included from /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.c:7:0:
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/SerialInterface.h:33:26: warning: multi-character character constant [-Wmultichar]
MODULE_LIST_SIGNATURE = ‘TSLM’,
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/SerialInterface.h:34:27: warning: multi-character character constant [-Wmultichar]
MODULE_EVENT_SIGNATURE = ‘TVEM’,
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.c:28:2: warning: multi-character character constant [-Wmultichar]
‘GBDK’,
In file included from ./include/uapi/linux/posix_types.h:5:0,
from ./include/uapi/linux/types.h:14,
from ./include/linux/compiler.h:164,
from ./include/linux/init.h:5,
from /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.c:1:
./include/linux/stddef.h:8:14: warning: initialization makes integer from pointer without a cast [-Wint-conversion]
#define NULL ((void *)0)
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.c:31:2: note: in expansion of macro ‘NULL’
NULL,
./include/linux/stddef.h:8:14: note: (near initialization for ‘KernelDebugDataBlock.Reserved’)
NULL,
/tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper_main.c:54:13: warning: ‘make_range_writable’ defined but not used [-Wunused-function]
static void make_range_writable(void *start, void *end)
CC [M] /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/SequentialModuleInfo.o
In file included from /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/SequentialModuleInfo.h:2:0,
from /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/SequentialModuleInfo.c:2:
LD [M] /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper.mod.o
LD [M] /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper.ko
make: Leaving directory ‘/usr/src/linux-source-4.15.0/linux-source-4.15.0’insmod: ERROR: could not insert module /tmp/LinuxKernelDebugHelper-fab70f0d-4c3f-4f93-b524-7e5638fb5ccc/LinuxKernelDebugHelper.ko: Invalid module format
July 25, 2018 at 04:37 #21476support
This looks like the build tools you are using are not compatible with the target system. Please try checking the ‘dmesg’ output for more details (e.g. wrong kernel version, incompatible architecture, etc). If nothing helps, please try building and loading the module manually. Once VisualKernel detects that it is loaded, it won’t try to rebuild it anymore.
