Sysprogs forums › Forums › VisualKernel › VisualKernel does not appear in VS2015 after re-installing
- This topic has 11 replies, 2 voices, and was last updated 9 years, 4 months ago by
May 9, 2017 at 10:59 #11184
fstuetz
ParticipantI uninstalled VisualKernel v2.1 and VS community 2015 completely.
After reinstalling (first VS2015 then VK) VK appears in my installed Programs, but not in the VS2015 IDE.
E.g., the VK project templates do not appear.May 10, 2017 at 06:59 #11192support
Please try running devenv.exe /ResetSkipPkgs. If this does not help, please double-check that the “C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\Extensions\Sysprogs\VisualKernel\extension.vsixmanifest” file exists and is not corrupt. If this does not help either, please try running devenv.exe /log and check the ActivityLog.xml file for messages related to VisualKernel.
May 10, 2017 at 13:31 #11196fstuetz
ParticipantHi and thanks so far!
I checked the file extension.vsixmanifest, it seems ok.
The log entries do not show any problem. They state “Successfully loaded extension…” and “Extension is enabled…”But still there is no VisualKernel support in VS2015.
Another hint about my activity history:
I had installed VS2017. This caused several problems in VS2015. As a result I had to uninstall both VS2017 and VS2015.So I still hope very much that someone can help me.
May 11, 2017 at 18:08 #11201support
Thanks for checking this. If the extension is loaded, please check if it appears under Tools->Extensions and Updates and whether the Help->About VisualKernel command is visible. If yes, please let us know what exact functionality is broken.
May 12, 2017 at 09:17 #11205fstuetz
VisualKernel does appear in Tools->Extensions and Updates, but not in the Help menu.
May 12, 2017 at 19:01 #11208support
This could be caused by some strange interference with VisualGDB. Please try uninstalling VisualGDB and see if VisualKernel menus reappear. If yes, please let us know your VisualGDB and VisualKernel versions.
May 12, 2017 at 21:17 #11217fstuetz
VisualGDB was currently not installed. It had been before I uninstalled and re-installed VS2015 and VisualKernel.
So today I tried installing VisualGDB 5.2r8 too.
The behaviour was the same – both appear in Tools->Extensions and Updates, but not in the Help menu or project templates.
After uninstalling VisualGDB again the situation was as before.The VisualKernel Version is: 2.1r2
I had 2 versions of VisualGDB in use. The first one a few months ago was: 5.1r6.
I tried updating to 5.2r8. But I got errors when starting VS2015. So I had to return to 5.1r6 again.May 12, 2017 at 21:54 #11218support
KeymasterOK, this is starting to look like a corrupt VS installation. Please try installing VisualKernel from another user account and check if it works. If it does, please try renaming/removing per-user Visual Studio folders and registry keys so that VS can reinitialize its environment and then reinstall VisualKernel again.
May 15, 2017 at 11:16 #11226fstuetz
ParticipantIndeed, this seems to be the problem.
After installing VisualKernel as new user, it worked.
However, I could not fix the problem for the standard user which I would prefer to use. Deleting these folders did not help:
C:\Users\<user>\AppData\Roaming\Microsoft\VisualStudio\14.0
C:\Users\<user>\AppData\Roaming\VisualKernelConcerning the per-user registry entries of VisualStudio: I don’t know where they are. Can you give me a hint?
Thank you so far!
May 15, 2017 at 19:01 #11228support
You don’t need to delete the VisualKernel folders/keys, only the Visual Studio ones:
- C:\Users\<user>\AppData\Roaming\Microsoft\VisualStudio\14.0
- C:\Users\<user>\AppData\Local\Microsoft\VisualStudio\14.0
- HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\14.0
- HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\14.0_Config
We recommend renaming the folders/keys before you confirm that it solves the problem in case you accidentally delete something critical.
May 16, 2017 at 09:14 #11238fstuetz
Thank you very much! Renaming the registry entries solved my problem.
Are your developers interested in the buggy contents of
HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\14.0 and HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\14.0_Config
that caused the problem?May 17, 2017 at 05:32 #11242support
Unfortunately, VS registry can get corrupt in many different ways, so one specific instance won’t be of much help. You could try getting a diff of the .reg files from the old and the new key and quickly check if there is anything obviously wrong there (or send the diff to us if the amount of changes is relatively small), but unless it gets obvious from the first glance, investigating it further won’t be worth the time.
