VisualGDBBuildServer not support mono 4
Sysprogs forums › Forums › VisualGDB › VisualGDBBuildServer not support mono 4
  • #440
    Please provided one can run with mono4, after update, my ubuntu 12.10 now install mono 4.0, and server not running anymore. or you can opensource the server, so anyone can hack it.
    #2113
    Could you please provide more detailed info on what exactly fails on mono 4.0?
    #2110
    it said mono2 clr something bla bla, i just removed mono4 and install 2 and everything works now.
    new 2.8 in my machine, when press F11 step in, vs11 will hang every time(need kill). but 2.7 works, guess F5 bind caused it?
    #2111
    the problem maybe cause unsuccessful build. my build will run some test failed, but compile ok. and i continue debug it with f5, them when f11, hang. if build ok, everything works.
    #2112
    OK, thanks, we’ll look into it.
