Sysprogs forums › Forums › VisualGDB › VisualGDB windows not working in VS2019
- This topic has 14 replies, 3 voices, and was last updated 6 years, 9 months ago by
July 4, 2019 at 16:43 #25251
wtywtykk
I upgraded to vs2019 and VGDB 5.4r9 today. And I found the semihosting window stopped working. When I switch the tab, the window just keep displaying the content of the former tab. It seems that the window wasn’t redrawing itself. Pressing keys do send the keys to the mcu, but window doesn’t show any change. Other VGDB windows also have this problem.
I’m using openocd and CMSIS-DAP, and the mcu is stm32f401.
There’s a video showing the problem. http://45.77.66.194/20190704-232057957.flv
Thanks!
You must be logged in to view attached files.July 4, 2019 at 17:45 #25253support
This is actually a bug introduced by the new “Optimize rendering for screens with different pixel densities” setting in VS2019, that prevents the tool windows based on the WinForms technology from being shown correctly. We have added a workaround for this in the following build: VisualGDB-5.4.109.3224.msi
Please let us know if it doesn’t solve the problem.
July 6, 2019 at 18:44 #25274ExtSol
ParticipantIt’s working. Thank you!
July 7, 2019 at 00:51 #25276ExtSol
ParticipantNow, when i start debugging i get a following error:
Failed to start GDB session
(gdb begin)
— GDB Session —
Thank you for your purchase. Your license details will be loaded and shown in the next 24-48 hours.
-gdb-version
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 8.0.1\n”
~”Copyright (C) 2017 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-w64-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
This GDB was configured as “–host=i686-w64-mingw32 –target=arm-eabi”.
~”For help, type \”help\”.\n”
~”Reading symbols from D:\\Drive\\Project\\uc\\WIFIRemote_VisualGDB\\WIFIRemote\\VisualGDB\\Debug\\WIFIRemote…”
~”done.\n”
^done
-list-features
-gdb-set print demangle off
^done
set remotetimeout 60
&”set remotetimeout 60\n”
=cmd-param-changed,param=”remotetimeout”,value=”60″
^done
target remote :50888
&”target remote :50888\n”
~”Remote debugging using :50888\n”
~”Reset_Handler () at C:/Users/ExtSol/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/StartupFiles/startup_stm32f103xb.c:572\n”
~”572\t\tfor (pSource = &_sidata, pDest = &_sdata; pDest != &_edata; pSource++, pDest++)\n”
*stopped,frame={addr=”0x08000460″,func=”Reset_Handler”,args=[],file=”C:/Users/ExtSol/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/StartupFiles/startup_stm32f103xb.c”,fullname=”C:\\Users\\ExtSol\\AppData\\Local\\VisualGDB\\EmbeddedBSPs\\arm-eabi\\com.sysprogs.arm.stm32\\STM32F1xxxx\\StartupFiles\\startup_stm32f103xb.c”,line=”572″},thread-id=”1″,stopped-threads=”all”
^done
info shared
&”info shared\n”
~”No shared libraries loaded at this time.\n”
^done
mon halt
&”mon halt\n”
^done
mon reset init
&”mon reset init\n”
@”target halted due to debug-request, current mode: Thread \n”
@”xPSR: 0x01000000 pc: 0x08000460 msp: 0x20005000\n”
^done
load
&”load\n”
~”Loading section .isr_vector, size 0x10c lma 0x8000000\n”
+download,{section=”.isr_vector”,section-size=”268″,total-size=”16199″}
+download,{section=”.isr_vector”,section-sent=”268″,section-size=”268″,total-sent=”268″,total-size=”16199″}
~”Loading section .text, size 0x400 lma 0x800010c\n”
+download,{section=”.text”,section-size=”1024″,total-size=”16199″}
~”Loading section .init_array, size 0x4 lma 0x800050c\n”
+download,{section=”.init_array”,section-size=”4″,total-size=”16199″}
~”Loading section .fini_array, size 0x4 lma 0x8000510\n”
+download,{section=”.fini_array”,section-size=”4″,total-size=”16199″}
~”Start address 0x8000460, load size 1300\n”
~”Transfer rate: 7 KB/sec, 325 bytes/write.\n”
^done
-data-evaluate-expression “sizeof(void *)”
^done,value=”4″
-data-evaluate-expression “sizeof(int)”
^done,value=”4″
-data-evaluate-expression “sizeof(short)”
^done,value=”2″
-data-evaluate-expression “sizeof(long)”
^done,value=”4″
-data-evaluate-expression “sizeof(long long)”
^done,value=”8″
-data-evaluate-expression “sizeof(char)”
^done,value=”1″
-data-evaluate-expression “sizeof(wchar_t)”
^error,msg=”No symbol \”wchar_t\” in current context.”
-data-evaluate-expression “sizeof(float)”
^done,value=”4″
-data-evaluate-expression “sizeof(double)”
^done,value=”8″
-data-evaluate-expression “sizeof(long double)”
^done,value=”8″
info target
&”info target\n”
~”Symbols from \”D:\\Drive\\Project\\uc\\WIFIRemote_VisualGDB\\WIFIRemote\\VisualGDB\\Debug\\WIFIRemote\”.\n”
~”Remote serial target in gdb-specific protocol:\n”
~”Debugging a target over a serial line.\n”
~”\tWhile running this, GDB does not access memory from…\n”
~”Local exec file:\n”
~”\t`D:\\Drive\\Project\\uc\\WIFIRemote_VisualGDB\\WIFIRemote\\VisualGDB\\Debug\\WIFIRemote’, file type elf32-littlearm.\n”
~”\tEntry point: 0x8000460\n”
~”\t0x08000000 – 0x0800010c is .isr_vector\n”
~”\t0x0800010c – 0x0800050c is .text\n”
~”\t0x0800050c – 0x08000510 is .init_array\n”
~”\t0x08000510 – 0x08000514 is .fini_array\n”
~”\t0x20000000 – 0x20000000 is .data\n”
~”\t0x20000000 – 0x2000001c is .bss\n”
^done
-data-evaluate-expression “&_estack”
^done,value=”0x20005000″
-var-create – * “*((void **)0x20004ffc)”
^done,name=”var1″,numchild=”0″,value=”0x8000491 <Reset_Handler+48>”,type=”void *”,has_more=”0″
-var-assign “var1″ 0x64ab982e
^done,value=”0x64ab982e”
-data-evaluate-expression “\*\(\(void\ \*\*\)0x20004ffc\)”
-break-insert -f main
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080003a0″,func=”main”,file=”WIFIRemote.c”,fullname=”D:\\Drive\\Project\\uc\\WIFIRemote_VisualGDB\\WIFIRemote\\WIFIRemote\\WIFIRemote.c”,line=”7″,thread-groups=[“i1″],times=”0″,original-location=”main”}— openocd —
C:\Users\ExtSol\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 50888” -c “telnet_port 50889” -f interface/stlink.cfg -f target/stm32f1x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2019-06-25) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1000 kHz
Info : STLINK V2J31S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.228024
Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : Listening on port 50888 for gdb connections
Info : Listening on port 50889 for telnet connections
Info : accepting ‘gdb’ connection on tcp/50888
Info : device id = 0x20036410
Info : flash size = 64kbytes
xPSR: 0x01000000 pc: 0x08000460 msp: 0x20005000What can i do?
July 7, 2019 at 00:55 #25277ExtSol
Participantbut i reinstall VisualGDB-5.4r9-trial everyting is ok, with the starting post problem “When I switch the tab, the window just keep displaying the content of the former tab”
after install the workaround, i get the same error
This reply was modified 6 years, 9 months ago by
ExtSol.
July 7, 2019 at 08:56 #25279ExtSol
ParticipantMy solution for this issue:
I download older version of Visual studio (downgrade to 2017) and VisualGDB-5.4r9-trial debugging feature working fine.
July 7, 2019 at 12:36 #25282wtywtykk
The workaround just works fine for me. My environment is: ARM toolchain 7.2.0/8.0.1/r3; STM32BSP 2019.06; OpenOCD 20190625-0.10.0
July 7, 2019 at 15:56 #25283ExtSol
Yes, worked for me too, but now, stop working, dont know why 🙁
Versions:
GCC: 7.2.0
GDB: 8.0.1
BSP: 2019.06
OpenOCD: 20190625-0.10.0
Visual Studio: 2017 (15.9.13) / 2019 (16.1.5)
July 7, 2019 at 16:21 #25284support
KeymasterIt’s hard to say what is going on as the log you attached is truncated. Please try using the latest build here: VisualGDB-5.4.110.3225.msi
Then enable diagnostic logs as shown here: http://visualgdb.com/support/logsubmit
Then please attach a screenshot of the error message and the full diagnostic log produced by VisualGDB and we help you get it to work.
July 7, 2019 at 17:51 #25288ExtSol
ParticipantI following the instructions:
- install: VisualGDB-5.4.110.3225.msi
- started VS 2019 Community
- i do the instructions: http://visualgdb.com/support/logsubmit
The issue is the some.
Here is the screenshot: https://imgur.com/a/t0PQL2w
Here is the source code: https://pastebin.com/shuhrcNK
And i uploaded the log file.
You must be logged in to view attached files.July 7, 2019 at 18:00 #25291support
KeymasterThanks, this looks like something GUI-related (the actual error is “Invoke/BeginInvoke cannot be called” shown on the screenshot).
Please try using View->Other Windows->VisualGDB Diagnostics Console to narrow this down. I.e. enable debug logging, reproduce the problem and share the diagnostic output from the diagnostic console.
July 7, 2019 at 18:08 #25294ExtSol
ParticipantJust a moment,
Visual Studio 2017 + VisualGDB-5.4.110.3225.msi are working fine.
only VS 2019 + VisualGDB-5.4.110.3225.msi not working.
I procedure the log which your request and i will try to reinstall VS 2019
July 7, 2019 at 18:11 #25296ExtSol
ParticipantHere is the diagnostic results:
Initializing assemblies: 9 msec
Registering factories: 75 msec
D:\Drive\Project\uc\WIFIRemote_VisualGDB\WIFIRemote\WIFIRemote\WIFIRemote.vcxproj is a VisualGDB project. Loading VisualGDB…
Initializing VisualGDB 5.4.110.3225
Checking fonts/colors: 9 msec
Level 2 initialization: 616 msec
Checking if a VisualGDB-based project is being loaded…: 837 msec => Loading VisualGDB
ShouldRedirectToVisualGDBImpl(): D:\Drive\Project\uc\WIFIRemote_VisualGDB\WIFIRemote\WIFIRemote\WIFIRemote-Debug.vgdbsettings vgdb://TargetPath=D:\Drive\Project\uc\WIFIRemote_VisualGDB\WIFIRemote\VisualGDB\Debug\WIFIRemote
Searching for active configuration for WIFIRemote\WIFIRemote.vcxproj…
Trying fast lookup…
Found! Configuration name = Debug
Trying fast lookup…
Trying fast lookup…
No RTOS found in D:\Drive\Project\uc\WIFIRemote_VisualGDB\WIFIRemote\VisualGDB\Debug\WIFIRemote
Launching gdbserver…
Launching C:\Users\ExtSol\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 56379” -c “telnet_port 56380” -f interface/stlink.cfg -c “transport select hla_swd” -f target/stm32f1x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”…
[+46567] ExecuteRawCommand(-gdb-version, f)
[+36] GDB command result:^done
[+0] ExecuteRawCommand(-list-features, f)
[+0] GDB command result:^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”]
[+0] ExecuteRawCommand(-gdb-set disassembly-flavor intel, f)
[+0] GDB command result:^error,msg=”No symbol \”disassembly\” in current context.”
[+0] ExecuteRawCommand(-gdb-set print demangle off, f)
[+1] GDB command result:^done
[+0] ExecuteRawCommand(set remotetimeout 60, c)
[+11] GDB command result:^done
[+0] ExecuteRawCommand(target remote :56379, c)
[+14] ExecuteRawCommand(info shared, c)
[+0] ExecuteRawCommand(mon halt, c)
[+10] GDB command result:^done
[+13] GDB command result:^done
[+0] ExecuteRawCommand(mon reset init, c)
[+29] GDB command result:^done
[+1] ExecuteRawCommand(mon report_flash_progress 1, c)
[+7] ExecuteRawCommand(load, c)
&”load\n”
+download,{section=”.isr_vector”,section-size=”268″,total-size=”139633″}
+download,{section=”.isr_vector”,section-sent=”268″,section-size=”268″,total-sent=”268″,total-size=”139633″}
~”Loading section .text, size 0x108c lma 0x800010c\n”
+download,{section=”.text”,section-size=”4236″,total-size=”139633″}
~”Loading section .init_array, size 0x4 lma 0x8001198\n”
+download,{section=”.init_array”,section-size=”4″,total-size=”139633″}
~”Loading section .fini_array, size 0x4 lma 0x800119c\n”
+download,{section=”.fini_array”,section-size=”4″,total-size=”139633″}
~”Loading section .data, size 0x64 lma 0x80011a0\n”
+download,{section=”.data”,section-size=”100″,total-size=”139633″}
~”Start address 0x8001080, load size 4612\n”
~”Transfer rate: 12 KB/sec, 922 bytes/write.\n”
^done
(gdb)
[+362] GDB command result:^done
[+2] ExecuteRawCommand(-data-evaluate-expression “sizeof(void *)”, f)
[+8] GDB command result:^done,value=”4″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(int)”, f)
[+10] GDB command result:^done,value=”4″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(short)”, f)
[+11] GDB command result:^done,value=”2″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(long)”, f)
[+0] GDB command result:^done,value=”4″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(long long)”, f)
[+1] GDB command result:^done,value=”8″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(char)”, f)
[+0] GDB command result:^done,value=”1″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(wchar_t)”, f)
[+1] GDB command result:^done,value=”4″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(float)”, f)
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(double)”, f)
[+0] GDB command result:^done,value=”8″
[+0] ExecuteRawCommand(-data-evaluate-expression “sizeof(long double)”, f)
Trying fast lookup…
[+24] ExecuteRawCommand(info target, c)
[+7] GDB command result:^done
[+2] ExecuteFrameSensitiveCommand(-data-evaluate-expression “&_estack”, -1, -1)
[+0] ExecuteRawCommand(-data-evaluate-expression “&_estack”, f)
[+9] GDB command result:^done,value=”0x20005000″
[+0] ExecuteFrameSensitiveCommand(-var-create – * “*((void **)0x20004ffc)”, -1, -1)
[+0] ExecuteRawCommand(-var-create – * “*((void **)0x20004ffc)”, f)
[+1] GDB command result:^done,name=”var1″,numchild=”0″,value=”0x80010b1 <Reset_Handler+48>”,type=”void *”,has_more=”0″
[+0] ExecuteRawCommand(-var-assign “var1″ 0x61d7663b, f)
[+2] GDB command result:^done,value=”0x61d7663b”
[+0] ExecuteFrameSensitiveCommand(-data-evaluate-expression “\*\(\(void\ \*\*\)0x20004ffc\)”, -1, -1)
[+0] ExecuteRawCommand(-data-evaluate-expression “\*\(\(void\ \*\*\)0x20004ffc\)”, f)
[+1] GDB command result:^done,value=”0x61d7663b”
[+0] ExecuteRawCommand(-break-insert -f main, f)
[+3] GDB command result:^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x08000fb4″,func=”main”,file=”WIFIRemote.c”,fullname=”D:\\Drive\\Project\\uc\\WIFIRemote_VisualGDB\\WIFIRemote\\WIFIRemote\\WIFIRemote.c”,line=”8″,thread-groups=[“i1″],times=”0″,original-location=”main”}
[+1612] ExecuteRawCommand(-gdb-exit, f)
[+19] GDB command result:^exitJuly 7, 2019 at 23:01 #25299ExtSol
ParticipantI repaired VS 2019 install and work fine. Then create new project, not work again.
Repaired again, and create new project, now works fine… this is a random error… A not have any idea why doing this.
Please analize this issue
July 9, 2019 at 00:35 #25317support
KeymasterThanks for the log file. It looks like some combination of settings is preventing VisualGDB from showing some of the tool windows before updating its state.
We have added more diagnostic logging to this build: VisualGDB-5.4.110.3226.msi
Please try reproducing the problem with it and send us the updated log from the VisualGDB Diagnostics Console.
