I recently started using VisualGDB for Linux applications. I have code in my Windows PC and am trying to run it on WSL2 in my same machine. I had a couple of questions regarding the same:
1. What is the recommended way to add folders with source and header files to the project/solution?
2. How do I refer to a text file? See the attached project as an example. I have tried putting the files in the project folder and using a relative path in code, though I get a seg fault.
You must be
