Sysprogs forums › Forums › VisualGDB › VisualGDB MSBuild way does not generate bin files
- This topic has 6 replies, 3 voices, and was last updated 7 years, 4 months ago by
Yuriy.
July 4, 2017 at 11:29 #11644
guntiss
ParticipantI’m using VisualGDB for STM32 embedded projects, and need to generate bin file. I am using MSBuild as build system. Although in the project settings “Embedded Project” -> “Generate .bin file” is set to Yes, the bin file is not generated in the file system. MCU debugging/programming goes without issues.
What I am missing here, how to generate bin file?
July 5, 2017 at 06:31 #11647support
Please try rebuilding the project. The .bin file should be generated in the same directory as the regular ELF file (with no extension).
If nothing helps, please try enabling diagnostic MSBuild output via Tools->Options->Projects and Solutions -> Build and Run and check for the details on the “GenerateBinFile” target.
July 19, 2017 at 10:48 #11761guntiss
ParticipantThanks a lot for great support. Yes diagnostics enabled to see that bin file is generated in the solution directory not project directory. It happened that I had totally different directories for project and solution.
July 20, 2017 at 01:59 #11770support
KeymasterGood to know it works. If you encounter further problems, feel free to open another topic.
November 15, 2018 at 18:22 #22716Yuriy
ParticipantHi!
I also have a problem with .bin file. Can I disable generating of this file? There are no option “Embedded Project” -> “Generate .bin file” in current VisualGDB version.
I enabled diagnostic MSBuild output via Tools->Options->Projects and Solutions -> Build and Run:
Target Performance Summary: 0 ms _SelectedFiles 1 calls 0 ms _SplitProjectReferencesByFileExistence 1 calls 0 ms SelectClCompile 1 calls 0 ms Build 1 calls ............ 547 ms Link 1 calls 603 ms ClCompile 1 calls 3403 ms GenerateBinFile 1 calls
I know, this happens because we are using external FLASH at address 0x60000000 and can’t specify offset for .bin file.
As result we got .bin file with size 1 611 264 460 bytes.On my SSD generating of bin file takes 3 seconds, but on standard HDD it takes tens of seconds!
In other projects generating of .bin file works fast enough. Have you a good solution for this problem?
November 16, 2018 at 07:07 #22721support
Yes, please try marking the sections for the external FLASH memory with the NOLOAD attribute in the linker script. This will prevent the objcopy tool from trying to place them in the same contiguous binary file as the regular FLASH sections.
November 16, 2018 at 14:45 #22724Yuriy
ParticipantHi! Marking these sections as NOLOAD solved problem, now .bin file has correct size. Thanks
