VisualGDB Keyboard Shortcuts?
Sysprogs forums Forums VisualGDB VisualGDB Keyboard Shortcuts?
  • #23856
    Seidleroni
    Are there keyboard shortcuts for the following items?
    1. Find Symbols in Solution
    2. Explore Source File
    3. Drop down and search list of methods (from the middle of the VisualGDB bar)
    #23864
    VisualGDB itself does not provide any global shortcuts, instead it registers commands with Visual Studio so that you can set shortcuts via the Visual Studio’s options dialog.
    The Find Symbols in Solution command is available in the Edit menu, so you can set a shortcut for it. Method enumeration doesn’t have a global command yet, so will try to add it in one of the next builds.
