Sysprogs forums › Forums › VisualGDB › VisualGDB hangs when creating new project
- This topic has 13 replies, 2 voices, and was last updated 8 years, 10 months ago by
jmkresse.
May 11, 2017 at 19:30 #11202
jmkresse
ParticipantOne of the VisualGDB users here reports that VisualGDB hangs when creating a new project.
He gets to the step labeled “New Linux Project” , and clicks on “Finish”. A pop-up shows VisualGDB doing a series of steps, and then disappears. At that point, the “New Linux Project” step is still on the screen, and VisualGDB is hung.
Do you have any ideas on things we can try to figure out what is wrong?
(Also is there a way to post screenshots on here?)
Thanks!
May 12, 2017 at 20:16 #11211support
If you are using VS2017, this could be caused by the bugs in the AddFilter() API in Visual Studio.
We are actually experimenting with editing the .vcxproj files directly instead of using the buggy API, so feel free to try this build and let us know if it solves the problem: http://sysprogs.com/files/tmp/VisualGDB-5.3.1.1509.msi
May 12, 2017 at 20:38 #11212jmkresse
ParticipantThanks! I’ll pass that along to that user.
I don’t think he was using VS2017, though; probably VS2015. I’ll check on that.
May 12, 2017 at 20:50 #11213support
If it was not VS2017, we would recommend attaching another VS instance to the hanging one and checking the call stack of the main thread. This should explain what exactly is causing the delay.
May 12, 2017 at 20:53 #11214jmkresse
ParticipantOk, thanks for the quick reply!
Would you please explain to me how to do that? I’m not that familiar with VS; most of my experience has been in embedded processors.
May 12, 2017 at 20:57 #11215support
No problem. Please follow the steps below:
- Ensure you have exactly 1 instance of Visual Studio running
- Start another VS instance
- Select Debug->Attach to process
- In the process list select devenv.exe (Visual Studio) and in the “types of code to attach” select “automatic”.
- Click “Attach”
- Click Debug->Break All
- Open the Debug->Windows->Threads window, locate the GUI thread and double-click on it
- Open the Debug->Windows->Call Stack window, select all frames and copy-paste them here
May 12, 2017 at 21:01 #11216jmkresse
ParticipantThanks! We’ll give that a try.
May 13, 2017 at 01:28 #11219jmkresse
ParticipantWe tried to follow those steps, but when we got to step 7, we saw 34 threads, but didn’t see a GUI thread. Also, when we tried clicking on a thread, they all just came back with “[External Code]” in the Call Stack window.
I have screenshots, and can attach them if you tell me how to do that.
Thanks!
May 14, 2017 at 17:02 #11222support
We have double-checked the window. The GUI thread should have the following attributes set:
- Both Category and Name should read “Main Thread”
- The Managed ID should be 1
In order to get past the “external code” issue, please right-click in the Call Stack window and select “Show External Code”.
Alternatively you can simply select Debug->Save Dump As, upload the dump file (~1GB) to dropbox and share a link so that we could investigate it on our side.
May 15, 2017 at 21:18 #11234jmkresse
ParticipantThank you for that clarification.
Here is the frame copy from the Call Stack window:
> WindowsBase.dll!System.Windows.Threading.DispatcherSynchronizationContext.Wait(System.IntPtr[] waitHandles, bool waitAll, int millisecondsTimeout) Unknown mscorlib.dll!System.Threading.SynchronizationContext.InvokeWaitMethodHelper(System.Threading.SynchronizationContext syncContext, System.IntPtr[] waitHandles, bool waitAll, int millisecondsTimeout) Unknown [Native to Managed Transition] [Managed to Native Transition] mscorlib.dll!System.Threading.WaitHandle.InternalWaitOne(System.Runtime.InteropServices.SafeHandle waitableSafeHandle, long millisecondsTimeout, bool hasThreadAffinity, bool exitContext) Unknown mscorlib.dll!System.Threading.WaitHandle.WaitOne(int millisecondsTimeout, bool exitContext) Unknown mscorlib.dll!System.Threading.WaitHandle.WaitOne() Unknown VisualGDB.exe!f61.h1.f.a_2() Unknown VisualGDB.exe!f61.x(f61.n2<int> a) Unknown VisualGDB.exe!ir1.Dispose() Unknown VisualGDB.exe!zk1.Dispose() Unknown VisualGDB.exe!kf.a1() Unknown VisualGDB.exe!z61.a1.c(kf a) Unknown VisualGDB.exe!z61.a1.d(string b, string a, z61.a1.h c) Unknown VisualGDB.exe!z61.o(SysprogsDevTools.Commands.RemoteHostSettings a) Unknown VisualGDB.exe!z61.o(SysprogsDevTools.Commands.RemoteHostSettings a) Unknown VisualGDB.exe!m1.i1(bool a) Unknown VisualGDB.exe!m1.t1() Unknown VisualGDB.exe!m1.n1_2(gq1.x a) Unknown VisualGDB.exe!hk.b(int a) Unknown VisualGDB.exe!hk.d1() Unknown VisualGDB.exe!hk.e(d8 a, d8.u b) Unknown VisualGDB.exe!d8.g(object b, System.EventArgs a) Unknown System.Windows.Forms.dll!System.Windows.Forms.Control.OnClick(System.EventArgs e) Unknown System.Windows.Forms.dll!System.Windows.Forms.Button.OnClick(System.EventArgs e) Unknown System.Windows.Forms.dll!System.Windows.Forms.Button.OnMouseUp(System.Windows.Forms.MouseEventArgs mevent) Unknown System.Windows.Forms.dll!System.Windows.Forms.Control.WmMouseUp(ref System.Windows.Forms.Message m, System.Windows.Forms.MouseButtons button, int clicks) Unknown System.Windows.Forms.dll!System.Windows.Forms.Control.WndProc(ref System.Windows.Forms.Message m) Unknown System.Windows.Forms.dll!System.Windows.Forms.ButtonBase.WndProc(ref System.Windows.Forms.Message m) Unknown System.Windows.Forms.dll!System.Windows.Forms.Button.WndProc(ref System.Windows.Forms.Message m) Unknown System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.OnMessage(ref System.Windows.Forms.Message m) Unknown System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.WndProc(ref System.Windows.Forms.Message m) Unknown System.Windows.Forms.dll!System.Windows.Forms.NativeWindow.DebuggableCallback(System.IntPtr hWnd, int msg, System.IntPtr wparam, System.IntPtr lparam) Unknown [Native to Managed Transition] [Managed to Native Transition] System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.LocalModalMessageLoop(System.Windows.Forms.Form form) Unknown System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(int reason, System.Windows.Forms.ApplicationContext context) Unknown System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessageLoop(int reason, System.Windows.Forms.ApplicationContext context) Unknown System.Windows.Forms.dll!System.Windows.Forms.Application.RunDialog(System.Windows.Forms.Form form) Unknown System.Windows.Forms.dll!System.Windows.Forms.Form.ShowDialog(System.Windows.Forms.IWin32Window owner) Unknown System.Windows.Forms.dll!System.Windows.Forms.Form.ShowDialog() Unknown VisualGDB.exe!yj.a_2(wo1 b, string a, string c) Unknown VisualGDBPackage2015.dll!u9<yj>.Execute(object b, int c, ref object[] a, ref object[] e, ref EnvDTE.wizardResult d) Unknown [Native to Managed Transition] [Managed to Native Transition] Microsoft.VisualStudio.Dialogs.dll!Microsoft.VisualStudio.Dialogs.ServiceHelper.AddProjectFromSelectedTemplate(Microsoft.VisualStudio.Dialogs.INewProjectDialogData dialog, string projectPath, bool isExclusive) Unknown Microsoft.VisualStudio.Dialogs.dll!Microsoft.VisualStudio.Dialogs.SVsDialogService.CreateProject(Microsoft.VisualStudio.Dialogs.INewProjectDialogData npdd) Unknown Microsoft.VisualStudio.Dialogs.dll!Microsoft.VisualStudio.Dialogs.SVsDialogService.InvokeDialog(Microsoft.Internal.VisualStudio.Shell.Interop.VSNEWPROJECTDLGINFO dlgInfo, out string bstrLocation) Unknown [Native to Managed Transition] [Managed to Native Transition] Microsoft.VisualStudio.Shell.14.0.dll!Microsoft.Internal.VisualStudio.PlatformUI.DataSource.Invoke(string verb, object pvaIn, out object pvaOut) Unknown Microsoft.VisualStudio.Shell.UI.Internal.dll!Microsoft.VisualStudio.PlatformUI.VsCommand.Execute(object parameter) Unknown PresentationFramework.dll!MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(System.Windows.Input.ICommandSource commandSource, bool userInitiated) Unknown PresentationFramework.dll!System.Windows.Controls.MenuItem.InvokeClickAfterRender(object arg) Unknown WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) Unknown WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.TryCatchWhen(object source, System.Delegate callback, object args, int numArgs, System.Delegate catchHandler) Unknown WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeImpl() Unknown WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(object state) Unknown mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Unknown mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Unknown mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) Unknown WindowsBase.dll!MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext executionContext, System.Threading.ContextCallback callback, object state) Unknown WindowsBase.dll!System.Windows.Threading.DispatcherOperation.Invoke() Unknown WindowsBase.dll!System.Windows.Threading.Dispatcher.ProcessQueue() Unknown WindowsBase.dll!System.Windows.Threading.Dispatcher.WndProcHook(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) Unknown WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) Unknown WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o) Unknown WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) Unknown WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.TryCatchWhen(object source, System.Delegate callback, object args, int numArgs, System.Delegate catchHandler) Unknown WindowsBase.dll!System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs) Unknown WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam) Unknown
May 16, 2017 at 05:48 #11235support
Thanks, this looks like the hang is related to VisualGDB. Could you please let us know the exact VisualGDB build (from VisualGDB.exe file properties) so that we could pinpoint this further?
Please also try manually killing the CppEngineHost.exe process next time the hang happens. If the hang is related to the Clang IntelliSense engine, this should help.
May 16, 2017 at 19:15 #11239jmkresse
After being able to repeat the issue at will previously, my user was not able to repeat it today. Instead, things glitched at an earlier point, but he was able to recover and work around the issue. For now, given he has a workaround, he doesn’t want to pursue this any further. If (when) that changes, I’ll get back to you.
For what it’s worth, the version we are using here is 5.2.15.1452.
Thanks!
May 17, 2017 at 05:34 #11243support
Thanks, according to the stack trace, VisualGDB was stuck waiting for a response from the Linux machine while trying to close an SSH connection. If you run into this problem again, please try updating your SSH server or try a different network connection (e.g. this could be caused by packet loss).
May 18, 2017 at 17:47 #11250jmkresse
ParticipantThanks! That explains why the issue was intermittent; I’m guessing he was hitting network congestion when he had the issue.
