VisualGDB fails to upload compiled sketch using Picoprobe CMSIS-DAP
Sysprogs forums › Forums › VisualGDB › VisualGDB fails to upload compiled sketch using Picoprobe CMSIS-DAP
  • #34494
    alef
    I am trying to use Picoprobe CMSIS-DAP to upload my Arduino sketch on a Raspberry Pi Pico. I can correctly configure and use the debugger with the same upload config, however I am not able to use picoprobe to simply upload the sketch. I can do this with no problems if I use Arduino IDE with the same sketch.
    The error I get is this one:
    Run “C:\Users\Tofanelli\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52\bin\openocd -f “interface/cmsis-dap.cfg” -f “target/rp2040.cfg” -s “C:\Users\Tofanelli\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52/share/openocd/scripts” -c “adapter speed 5000” -c “program {build.path}/Fearless_BS_rev03.ino.elf} verify reset exit”” in directory “” on local computer
    It seems that a “{” is lost just before {build path}. The command executed by Arduino IDE is this one:
    “C:\Users\Tofanelli\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52/bin/openocd” -f “interface/cmsis-dap.cfg” -f “target/rp2040.cfg” -s “C:\Users\Tofanelli\AppData\Local\Arduino15\packages\rp2040\tools\pqt-openocd\1.5.0-b-c7bab52/share/openocd/scripts” -c “adapter speed 5000” -c “program {C:\Users\Tofanelli\AppData\Local\Temp\arduino\sketches\64084FD4C7680A4F44A4758446B5E15B/Fearless_BS_rev02.ino.elf} verify reset exit”
    I’m using Visual Studio Community 2022 (version 17.5.3) and VisualGDB Custom Edition version 5.6R9 (build 4854).
    Could you give some hints to solve this problem? Thanks!
    #34505
    Thanks for reporting this. It looks like the RP2040 platform definition uses a slightly unexpected syntax for the upload command template: program {{build.path}/{build.project_name}.elf} expecting it to expand to program {full-path.elf}.
    Other platform definitions we checked used the “{{” to escape the “{” character, i.e. program {{{build.path}/{build.project_name}.elf}}.
    Normally, you should not need this command at all – simply configure OpenOCD via VisualGDB Project Properties -> Debug Settings, and use Debug -> Program and Start without Debugging to program the FLASH memory using the VisualGDB-level commands.
    If you would like to use the Arduino-level commands, you can also patch the C:\Users\<user>\Documents\ArduinoData\packages\rp2040\hardware\rp2040\<version>\platform.txt file by inserting the extra “{” and “}” to make it consistent with other platforms:
    tools.picoprobe_cmsis_dap.upload.pattern="{cmd}/bin/openocd" -f "interface/cmsis-dap.cfg" -f "target/rp2040.cfg" -s "{cmd}/share/openocd/scripts" -c "adapter speed 5000" -c "program {{{build.path}/{build.project_name}.elf}} verify reset exit"
    Please make sure you reload the project after patching the file.
    We will consider updating VisualGDB to handle it automatically, however as we want to minimize the chance of breaking other platforms, and as there are 2 easy workarounds, we will wait for feedback from other users before updating it on VisualGDB side.
    #34506
    alef
    I used the second solution and patched the platform.txt file as you suggested; the problem is now solved. The default location of the file is C:\Users\<user>\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\<version>\platform.txt instead of C:\Users\<user>\Documents\ArduinoData\packages\rp2040\hardware\rp2040\<version>\platform.txt
    As for the first workaround, I am not able to see the VisualGDB Project Properties -> Debug Settings -> Debug -> Program and Start without Debugging option. Attached you can find a screenshot of the options visible in my case. Is there any advanced developer option that I can enable in VisualGDB to see this entry?
    Thank you!
    #34509
    Good to know it works. The exact path of platform.txt depends on how the package was installed (different Arduino IDE variants use different directories), but as long as you found the file, it should work just fine.
    The Program and Start without Debugging is not a setting in VisualGDB Project Properties, it’s a command under the Debug menu in Visual Studio.
