VisualGDB fails to give proper error to build fail
Sysprogs forums Forums VisualGDB VisualGDB fails to give proper error to build fail
Viewing 15 posts - 1 through 15 (of 16 total)
  • #8637
    b.timofte
    I have the output
    1>c:\comp_4.9.2_testversion/bin/g++.exe -o File.exe -Wl,-Map,File.map -Wl,–allow-multiple-definition    -Wl,–start-group Debug/f1.o Debug/f2.o
    ….huge list of objects
    Debug/Xcp_UtilsStartStop.o Debug/_main.o    -Wl,–end-group
    makefile:137: recipe for target ‘Debug/File.exe’ failed
    process_begin: CreateProcess(C:\comp_4.9.2_testversion\bin\g++.exe, C:/comp_4.9.2_testversion/bin/g++.exe -o Debug/File.exe -Wl,-Map,File.map -Wl,–allow-multiple-definition -Wl,–start-group Debug/f1.o Debug/f2.o
    ..huge list of files
    -Wl,–end-group, …) failed.
    make (e=87): The parameter is incorrect.
    1>
    1>  mingw32-make: *** [Debug/File.exe] Error 87
    1>  ————————————————————-
    1>  Command exited with code 2
    1>  Executable: cmd.exe
    1>  Arguments: /c “C:\comp_4.9.2_testversion\bin\mingw32-make.exe” -j8 CONFIG=Debug
    1>  Directory: C:\ProjectFolderVS 1>VisualGDB : error : Command-line action failed
    What should i understand from this ? Where is the  error lol ?
    • This topic was modified 9 years, 7 months ago by b.timofte.
    #8641
    b.timofte
    I think the command  is too long (to make exe from .o)
    Is there any FLAG where i can pass this limitation ?
    • This reply was modified 9 years, 7 months ago by b.timofte.
    #8644
    b.timofte
    So the tool calls the linker (g++.exe) with a HUUGE list of object files. I guess the command is too long
    What solution shall i make ? Splitting the source code into smaller folder doesnt seems to work and its unreliable since the file number and filename length matters
    #8645
    b.timofte
    Is this forum dead lol ?
    I cant imagine i am the only one who compiles +1000 files.
    Is it possible to give as input to mingw linker *.o instead of the full list of objects file ?
    Maybe possible to tell the linker to make  a list of object files in a file and give this file as input ?
    Anyone ?!
    #8653
    Our support is located in the PST timezone, so we could not have answered you earlier. Sorry about that.
    You can configure VisualGDB to pass a list of source files via response files by modifying your Makefile as follows:
    ifeq ($(TARGETTYPE),APP)
    $(BINARYDIR)/$(TARGETNAME): $(all_objs) $(EXTERNAL_LIBS)
     $(LD) -o $@ $(LDFLAGS) $(START_GROUP) $(all_objs) $(LIBRARY_LDFLAGS) $(END_GROUP)
    endif
    should be replaced with this:
     @echo $(all_objs) > $@.in
     $(LD) -o $@ $(LDFLAGS) $(START_GROUP) @$@.in $(LIBRARY_LDFLAGS) $(END_GROUP)
    endif
    #8659
    b.timofte
    Hi
    It didnt worked
    The linker command looks wrong
    C:/SysGCC/mingw32/bin/g++.exe -o Debug/WindowsProject1.exe -Wl,-gc-sections    -Wl,–start-group @Debug/WindowsProject1.exe.in    -Wl,–end-group
    1>g++.exe : error : Debug/thisIsAveryLongFilenamY: No such file or directory
    1>  mingw32-make: *** [Debug/WindowsProject1.exe] Error 1
    1>  Makefile:137: recipe for target ‘Debug/WindowsProject1.exe’ failed
    1>  Arguments: /c “C:\SysGCC\mingw32\bin\mingw32-make.exe” -j8 CONFIG=Debug
    1>  Directory: C:\Users\timo\Desktop\Study\Embedded\STM32\VisualGDB\WindowsProject1\WindowsProject1
    1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.MakeFile.Targets(42,5): error MSB3073: The command “”C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDB.exe” /rebuild “C:\Users\timo\Desktop\Study\Embedded\STM32\VisualGDB\WindowsProject1\WindowsProject1\WindowsProject1.vcxproj” “/solution:C:\Users\timo\Desktop\Study\Embedded\STM32\VisualGDB\WindowsProject1\WindowsProject1.sln” “/config:Debug” “/platform:Win32″” exited with code 1.
    ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
    #8660
    b.timofte
    I wonder how you build this 9000+ files  linux kernel -_-” using visualGDB … Really insipring
    #8662
    Could you check the contents/size of the Debug/WindowsProject1.exe.in file? Does it list the files correctly or is it cut off?
    Regarding the Linux Kernel, we actually have a separate project for that – VisualKernel. You can look through this tutorial to get a brief idea: http://sysprogs.com/VisualKernel/tutorials/kernel/
    #8665
    b.timofte
    Ofcourse it list the files correctly
    #8670
    b.timofte
    I also tried this
    <TAB>@echo -g > $@.in
    <TAB>$(foreach obj,$(all_objs),cmd /c “echo $(obj) >> $@.in”)
    <TAB> $(LD) -o $@ $(LDFLAGS) $(START_GROUP) @$@.in $(LIBRARY_LDFLAGS) $(END_GROUP)
    endif
    #8671
    b.timofte
    For the first variant there is the file “WindowsProject1.exe.in” in debug -_-
    #8672
    b.timofte
    The first solution truncates the .c files with char length >~34 characters. So then it cant find them when linking…
    1>  C:/SysGCC/mingw32/bin/g++.exe -o Debug/17_01_Dev.exe -Wl,-Map,BswSim.map -Wl,–allow-multiple-definition    -Wl,–start-group @Debug/17_01_Dev.exe.in    -Wl,–end-group
    1>g++.exe : error : Debug/TRUNCATEDFILENAME: No such file or directory
    1>  Makefile:137: recipe for target ‘Debug/17_01_Dev.exe’ failed
    1>  mingw32-make: *** [Debug/17_01_Dev.exe] Error 1
    #8673
    b.timofte
    The second variant
    endif
    gives error
    1>  The system cannot execute the specified program.
    And in the Debug folder beside .dep and .o there is one 17_01_Dev.exe.in who contains “-g”
    Heeeelp
    #8674
    b.timofte
    With the first variant there is on 17_01_Dev.exe.in which contains the list of objects like
    Debug/file2.o Debug/file1.o …
    The last object name in this file is
    Debug/DcmAppl_DcmCheckRdbiResponseLengh
    but my file is in the Debug folder is
    DcmAppl_DcmCheckRdbiResponseLength.o
    Its missing the “t”
    Also the file 17_01_Dev.exe.in doesnt contain the list of all my objects
    I have objects from A to X alphabetically but it stops at D
    (in notepad it says it has 8191 characters)
    WTF O_O
    #8678
    b.timofte
    Finally it works with this !!
    $(file >$@.in,$^)
    endif
