VisualGDB: Error: Command-line action failed
Sysprogs forums Forums VisualGDB VisualGDB: Error: Command-line action failed
  • #22115
    cyborgium
    Whenever I try to build something in VS with visualGDB, I get the following output:
    Command exited with code 2
     Executable: C:\SysGCC\esp32\bin\bash.exe
     Arguments: --login -c "export IDF_PATH=/esp-idf/v3.1 && export BATCH_BUILD=1 && export -n PYTHONHOME && export LANG=en_US && cd /cygdrive/c/Users/anne/Desktop/ESP2/wdm_board/s32/wdm_board && make -j4 BUILD_DIR_BASE='/cygdrive/c/Users/anne/Desktop/ESP32/wdm_board/Debug' SDKCONFIG='/cygdrive/c/Users/anne/Desktop/ESP3dkconfig-debug' V=0"
     Directory:
    What could I be doing wrong?
    • This topic was modified 7 years, 4 months ago by support. Reason: formatting
    #22126
    The code 2 typically indicates a missing file, so it might be caused by some components of the toolchain missing or corrupt. As a quick check, please try running the same command line manually (simply copy the contents of both “executable” and “arguments” to a command prompt window). If it doesn’t help identify the problem, please try reinstalling the toolchain.
