VisualDDK-1.5.7.exe found two bug
Sysprogs forums Forums VisualDDK/VirtualKD discussion VisualDDK-1.5.7.exe found two bug
Viewing 1 post (of 1 total)
  • #518
    warsark
    ENV:VS2010+ VISUAL DDK 1.5.7
    1.Menu->Debug->Driver launch setting…
    the is %SYSTEMROOT%SYSTEM32DRIVERDRIVER.SYS,if change the value to:c:driver.sys,on target system,can’t start the driver,the error message is:filename,folder or volume is incorrent
    2.if run two vs2010 project,all project is SYS project,one is do nothine,the other one will debug,the vs2010 will crash
