Visual Studio gets stuck loading VisualGDB-based project
Sysprogs forums › Forums › VisualGDB › Visual Studio gets stuck loading VisualGDB-based project
  • #32509
    regus_pregus
    When loading pre-exisitng solution containing several VisualGDB-based projects, Visual Studio gets stuck with the progress message “Loading project 1 of 15” and never proceeds further.
    VisualGDB 5.6R4 (build 4534)
    Visual Studio Community 2022 64-bit (version 17.1.1)
    The same project tree was loading at some point in the past (definitely before upgrading to VisualGDB 5.6R4 and possibly before upgrading to VS 2022).
    #32510
    regus_pregus
    I fixed the problem. Turns out that the necessary toolchain and board-specific packages were not re-installed after the upgrade. After installing these the project loads fine. As a suggestion, it would be nice if an error message was given when these components are missing instead of just getting stuck forever while loading the project.
    #32512
    Normally, VisualGDB checks for missing packages when loading the project, and displays a window suggesting automatically installing the missing ones. Most likely, something else in your setup interfered with this mechanism.
    If you could confirm that a specific sequence of actions that can be reproduced from scratch, triggers the issue, we can gladly investigate it further (e.g. Create a project using the ARM toolchain -> Remove the toolchain via VisualGDB Package Manager -> Restart VS -> Open the project).
