Visual GDB / QT / Raspberry
Sysprogs forums Forums VisualGDB Visual GDB / QT / Raspberry
  • #958
    Jetty
    I just purchased Visual GDB and I have some questions about this tutorial: http://visualgdb.com/tutorials/raspberry/qt-cross/
    How can we use for example the connect function who need to know the QApplication object create in the main ? I need this because I need to create new slots.
    Is there a better way than create the “button or other signal senders” and join/link them in qt designer ?
    Best Regards.
    Jetty
    #3509
    You can get the pointer to the active QApplication object via QApplication::instance() method as described here: http://qt-project.org/forums/viewthread/9319
    You can link the signals/slots with handlers using the Qt plugin for Visual Studio, however it is not as powerful as the WinForms or WPF editors.
