VBoxGDB compile
Sysprogs forums Forums Other tools & products VBoxGDB compile
Viewing 1 post (of 1 total)
  • #648
    alexk
    I’m trying to build/use VBoxGDB (http://sysprogs.com/VBoxGDB/) to debug pre OS code in VirtualBOX 4.2.18 (OSE). VirtualBOX is built local.
    Current version VBoxGDB-0.1 and VBoxGDB.sln shows the following in VS2010.
    C:_WorkVBoxGDBVBoxGDB-0.1VBoxGDBVBoxGDB.vcxproj : error : The imported project “C:_WorkbzslibBazisLibIncludes.props” was not found. Confirm that the path in the declaration is correct, and that the file exists on disk.
    C:_Workbzslibbzscorebzscore.vcxproj : error : Project “C:_Workbzslibbzscorebzscore.vcxproj” could not be found.
    C:_Workbzslibbzsnetbzsnet.vcxproj : error : Project “C:_Workbzslibbzsnetbzsnet.vcxproj” could not be found.
    C:_WorkVBoxGDBGDBServerFoundationGDBServerFoundation.vcxproj : error : The imported project “C:_WorkbzslibBazisLibIncludes.props” was not found. Confirm that the path in the declaration is correct, and that the file exists on disk.
    What projects are necessary to built the VBoxGDB?
    Will it work with VirtualBox 4.2? (Or there is strict limitation to VirtualBox 4.1)
    Thank you,
    Alex
