Uvision proj. compile errors
Sysprogs forums › Forums › VisualGDB › Uvision proj. compile errors
  • #33403
    dmas
    HI
    Trying to import a keil uVision proj of an STM32WB55 device.
    I am getting a bunch of errors when compiling some ST32WB55 code. This is source code taken from official ST repo.
    <div>The error I get:</div>
    <div></div>
    <div><i>#define $$com.sysprogs.bspoptions.<wbr />primary_memory$$_layout 1
    fatal error: error in backend: Cannot select: intrinsic %llvm.arm.isb
    armclang.exe: error: clang frontend command failed with exit code 70 (use -v to see invocation)
    Product: MDK Professional 5.36
    Component: ARM Compiler 6.6.4 Long Term Maintenance
    Tool: armclang [5c78ac00]
    Target: arm-arm-none-eabi
    armclang.exe: note: diagnostic msg: PLEASE submit a bug report to http://ds.arm.com/developer-<wbr />resources/ds-5-technical-<wbr />support/ and include the crash backtrace, preprocessed source, and associated run script.
    PLEASE ATTACH THE FOLLOWING FILES TO THE BUG REPORT:
    Preprocessed source(s) and associated run script(s) are located at:
    armclang.exe: note: diagnostic msg: …\stm32wbxx_hal_<wbr />cortex-ee90ba.c
    armclang.exe: note: diagnostic msg: …\stm32wbxx_hal_<wbr />cortex-ee90ba.sh
    warning: ‘armv4t’ is unsupported in this version of the product
    In file included from <built-in>:316:
    <command line>:3:14: warning: ISO C99 requires whitespace after the macro name [-Wc99-extensions]
    armclang.exe: note: diagnostic msg: …\stm32wbxx_hal_<wbr />flash-aca689.c
    armclang.exe: note: diagnostic msg: …\stm32wbxx_hal_<wbr />flash-aca689.sh
    Failed to compile stm32wbxx_hal_flash.c. armclang.exe exited with code 70</i></div>
    #33406
    Please refer to the following tutorial for detailed troubleshooting instructions: https://visualgdb.com/tutorials/arm/import/diagnose/
