using another framework
Sysprogs forums Forums VisualGDB using another framework
  • #9583
    dydrax
    Hi i want to use PowerVR framework for developt grapich in android ,
    but when i use it there is many error,
    i look at project properties $(VC_IncludePath);$(WindowsSDK_IncludePath); ….. is set to exclude directory in VC directory,
    so i delete that path and minimize the error , but still there is an error even cmath is error it say EMIT is not a typename in cmath sourcecode
    • This topic was modified 9 years, 3 months ago by dydrax.
    #9586
    VisualGDB does not use the VC_IncludePath and other directories when compiling the Android code. Which version of VisualGDB are you using?
    #9593
    dydrax
    I’m using visualGDB 5.2 , and use the standart library that they provided in ndk directory
    but i’m still can’t use the framework to my code , how can i use another 3rd library to my code it has own build in the jni folder
    #9605
    Please try following the instructions from the this page on referencing prebuilt libraries from other modules.
