Sysprogs forums › Forums › VisualGDB › Unit test xml report not Junit compatible
- This topic has 11 replies, 3 voices, and was last updated 6 years, 7 months ago by
Roman.Thiel.
December 5, 2019 at 15:03 #26732
Markg
ParticipantHello
We are integrating our unit tests into our jenkins environment. For the test results we generate the xml report. Is it possible to have this Junit compatible? This way it is easy integratable with jenkins.
Regards,
Mark
December 5, 2019 at 16:40 #26737support
Although VisualGDB cannot directly generate a Junit-compatible output, it can be configured to generate the outputs in the Visual Studio/MSTest test report format.
You can do this via the following command line
VisualGDB.exe /runtests <...> /vsoutput:<output file>
As both JUnit and MSTest test report formats are very popular, there are various open-source translators between them, so we would advise simply running one of them after VisualGDB returns.
December 6, 2019 at 15:30 #26763Markg
ParticipantDo you have a suggestion on which tool to use? It does not seem to work with the general plugins of jenkins (xunit / MStest
December 6, 2019 at 17:51 #26777support
KeymasterSorry, we have not explicitly tested VisualGDB with Jenkins yet. Producing the .trx file with the /vsoutput option and then using the regular MSTest plugin should normally work. If not, please share the details and we will try to help you configure it.
December 9, 2019 at 17:42 #26815Markg
ParticipantI’ve ran the unit test in jenkins, I made it fail intentionally. You can find the results file below. This results file Is given to MS test plugin and it does not detect test results.
Jenkins message: [MSTEST-PLUGIN] INFO processing test results in file(s) unit_test_results.trx </span></div> [MSTEST-PLUGIN] INFO processing report file: C:\Users\Mark\.jenkins\workspace\Example_Pipeline\unit_test_results.trx </span></div> [MSTEST-PLUGIN] WARNING Unable to delete the file C:\Users\Mark\.jenkins\workspace\Example_Pipeline\temporary-junit-reports </span></div> [MSTEST-PLUGIN] INFO This file is a reserved temporary file. You can delete it safely. </span></div> [MSTEST-PLUGIN] INFO XML coverage report file not found: C:\Users\Mark\.jenkins\workspace\Example_Pipeline\vstest.coveragexml </span></div> [MSTEST-PLUGIN] INFO XML coverage report file not found: C:\Users\Mark\.jenkins\workspace\Example_Pipeline\unit_test_results.coveragexml </span></div> [MSTEST-PLUGIN] SEVERE None of the test reports contained any result.
.trx file content:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <TestRun id="e04afaec-3698-4b27-86ff-9144e00e4724" name="CICD_Test_UnitTest-Debug" xmlns="http://microsoft.com/schemas/VisualStudio/TeamTest/2010"> <ResultSummary> <Counters total="1" executed="1" passed="0" failed="1" /> </ResultSummary> <TestDefinitions> <UnitTest name="CalcTestGroup::Add" id="733861c8-0c1f-4070-9503-8682f091c389"> <Execution id="54b2b785-2774-4785-a349-bed7e4357b43" /> </UnitTest> </TestDefinitions> <TestLists> <TestList name="All Tests" id="89b12475-5d59-4897-8a17-b74cd442d0de" /> </TestLists> <Results> <UnitTestResult executionId="54b2b785-2774-4785-a349-bed7e4357b43" testId="733861c8-0c1f-4070-9503-8682f091c389" testName="CalcTestGroup::Add" duration="00:00:00.1340000" startTime="09/12/2019 11:12:10" endTime="09/12/2019 11:12:10" outcome="Failed" testListId="89b12475-5d59-4897-8a17-b74cd442d0de"> <Output> <TextMessages> <Message> Calc_Tests.cpp:19: error: Failure in TEST(CalcTestGroup, Add) expected <1 0x1> but was <2 0x2> .</Message> </TextMessages> <ErrorInfo> <Message>expected <1 0x1> but was <2 0x2></Message> <StackTrace>at TEST_CalcTestGroup_Add_Test::testBody in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Calc_Tests.cpp:line 19 at helperDoTestBody in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 93 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at Utest::run in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 599 at UtestShell::runOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 211 at helperDoRunOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 118 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at UtestShell::runOneTest in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 185 at TestRegistry::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\TestRegistry.cpp:line 87 at CommandLineTestRunner::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 124 at CommandLineTestRunner::runAllTestsMain in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 83 at CommandLineTestRunner::RunAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 52 at main in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Main.cpp:line 33 </StackTrace> </ErrorInfo> </Output> </UnitTestResult> </Results> </TestRun>
December 9, 2019 at 18:05 #26822support
KeymasterThanks for checking this. It looks like some minor structural differences between the .trx file generated by VisualGDB and the files expected by the Jenkins tools are interfering with the parsing.
Please try the following steps to diagnose it:
- Create a dummy C# unit test with the MSTest framework. Run it with MSTest.exe and obtain a .trx file.
- Update your Jenkins setup to use a fixed .trx file generated in step 1 instead of the one produced by VisualGDB.
- Check if the test results are imported correctly. If not, double-check the Jenkins setup.
- If the .trx file produced by MSTest works, but the one produced by VisualGDB doesn’t, try eliminating the differences between them. E.g. change the test names in one of the .trx files to match the other one and then try adding the elements present in another .trx file until Jenkins starts recognizing it.
Once you determine what part of the .trx file is interfering with Jenkins, please let us know and we will update VisualGDB to generate it in a way expected by the Jenkins tools.
December 10, 2019 at 14:22 #26834Markg
ParticipantI’ve looked up a random trx file generated by mstest.
That one works fine with the mstest plugin (on jenkins)
if i remove the following line the file stops working. So guess it has something to do with that: (it is missing in the visual gdb generated file)
<TestMethod codeBase=”c:/dev/pickles-results-harne…
https://github.com/x97mdr/pickles/blob/master/src/Pickles/Pickles.Test/results-example-mstest.trx
I’ve made it a bit smaller so it is easier to compare it to the one generated by visual gdb (the one posted above) :
Fail to add two numbers Given I have entered 50 into the calculator -> done: Steps.GivenIHaveEnteredSomethingIntoTheCalculator(50) (0.0s) And I have entered -1 into the calculator -> done: Steps.GivenIHaveEnteredSomethingIntoTheCalculator(-1) (0.0s) When I press add -> done: Steps.WhenIPressAdd() (0.0s) Then the result should be -5000 on the screen -> error: Assert.NotEqual() Failure Test method Pickles.TestHarness.MSTest.AdditionFeature.FailToAddTwoNumbers threw exception: Should.Core.Exceptions.NotEqualException: Assert.NotEqual() Failure at Pickles.TestHarness.MSTest.Steps.ThenTheResultShouldBePass(Int32 result) in C:\dev\pickles-results-harness\Pickles.TestHarness\Pickles.TestHarness.MSTest\Steps.cs:line 28 at lambda_method(Closure , IContextManager , Int32 ) at TechTalk.SpecFlow.Bindings.MethodBinding.InvokeAction(IContextManager contextManager, Object[] arguments, ITestTracer testTracer, TimeSpan& duration) at TechTalk.SpecFlow.Bindings.StepDefinitionBinding.Invoke(IContextManager contextManager, ITestTracer testTracer, Object[] arguments, TimeSpan& duration) at TechTalk.SpecFlow.Infrastructure.TestExecutionEngine.ExecuteStepMatch(BindingMatch match, Object[] arguments) at TechTalk.SpecFlow.Infrastructure.TestExecutionEngine.ExecuteStep(StepArgs stepArgs) at TechTalk.SpecFlow.Infrastructure.TestExecutionEngine.OnAfterLastStep() at TechTalk.SpecFlow.TestRunner.CollectScenarioErrors() at Pickles.TestHarness.MSTest.AdditionFeature.ScenarioCleanup() in C:\dev\pickles-results-harness\Pickles.TestHarness\Pickles.TestHarness.MSTest\Addition.feature.cs:line 0 at Pickles.TestHarness.MSTest.AdditionFeature.FailToAddTwoNumbers() in c:\dev\pickles-results-harness\Pickles.TestHarness\Pickles.TestHarness.MSTest\Addition.feature:line 18
December 10, 2019 at 16:08 #26838Markg
ParticipantI have applied the fixes manually to the visual gdb created file and now it works! So if you do a diff on the two files posted below you should be able to generate files which can be used in jenkins.
Original file:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <TestRun id="590287a4-ce44-4bd5-883a-c510e6700676" name="CICD_Test_UnitTest-Debug" xmlns="http://microsoft.com/schemas/VisualStudio/TeamTest/2010"> <ResultSummary> <Counters total="3" executed="3" passed="2" failed="1" /> </ResultSummary> <TestDefinitions> <UnitTest name="CalcTestGroup::Multiply" id="f02fe075-6b68-4463-8b8d-cdbc0e1cb81e"> <Execution id="726f3d8f-8373-41c6-b6a2-6ddfc56f7039" /> </UnitTest> <UnitTest name="CalcTestGroup::Subtract" id="f50a734f-ffb2-4689-a82c-eb3043299a56"> <Execution id="ca9f4741-fac8-4190-b7fd-87244cffd7aa" /> </UnitTest> <UnitTest name="CalcTestGroup::Add" id="af68fb44-0096-4bab-966b-dedac12510d6"> <Execution id="cd3e14be-b33a-4203-818c-1d11944c47d0" /> </UnitTest> </TestDefinitions> <TestLists> <TestList name="All Tests" id="18bddc40-d190-4007-8170-ac27c2ba55d6" /> </TestLists> <Results> <UnitTestResult executionId="726f3d8f-8373-41c6-b6a2-6ddfc56f7039" testId="f02fe075-6b68-4463-8b8d-cdbc0e1cb81e" testName="CalcTestGroup::Multiply" duration="00:00:00" startTime="10/12/2019 16:02:22" endTime="10/12/2019 16:02:22" outcome="Passed" testListId="18bddc40-d190-4007-8170-ac27c2ba55d6"> <Output> <TextMessages> <Message>.</Message> </TextMessages> </Output> </UnitTestResult> <UnitTestResult executionId="ca9f4741-fac8-4190-b7fd-87244cffd7aa" testId="f50a734f-ffb2-4689-a82c-eb3043299a56" testName="CalcTestGroup::Subtract" duration="00:00:00.0020000" startTime="10/12/2019 16:02:22" endTime="10/12/2019 16:02:22" outcome="Passed" testListId="18bddc40-d190-4007-8170-ac27c2ba55d6"> <Output> <TextMessages> <Message>.</Message> </TextMessages> </Output> </UnitTestResult> <UnitTestResult executionId="cd3e14be-b33a-4203-818c-1d11944c47d0" testId="af68fb44-0096-4bab-966b-dedac12510d6" testName="CalcTestGroup::Add" duration="00:00:00.1150000" startTime="10/12/2019 16:02:22" endTime="10/12/2019 16:02:22" outcome="Failed" testListId="18bddc40-d190-4007-8170-ac27c2ba55d6"> <Output> <TextMessages> <Message> Calc_Tests.cpp:19: error: Failure in TEST(CalcTestGroup, Add) expected <1 0x1> but was <2 0x2> .</Message> </TextMessages> <ErrorInfo> <Message>expected <1 0x1> but was <2 0x2></Message> <StackTrace>at TEST_CalcTestGroup_Add_Test::testBody in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Calc_Tests.cpp:line 19 at helperDoTestBody in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 93 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at Utest::run in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 599 at UtestShell::runOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 211 at helperDoRunOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 118 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at UtestShell::runOneTest in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 185 at TestRegistry::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\TestRegistry.cpp:line 87 at CommandLineTestRunner::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 124 at CommandLineTestRunner::runAllTestsMain in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 83 at CommandLineTestRunner::RunAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 52 at main in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Main.cpp:line 33 </StackTrace> </ErrorInfo> </Output> </UnitTestResult> </Results> </TestRun>
Fixed file:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <TestRun id="191623c6-8a94-4bb3-b617-00a32d143bd2" name="CICD_Test_UnitTest-Debug" xmlns="http://microsoft.com/schemas/VisualStudio/TeamTest/2010"> <ResultSummary> <Counters total="3" executed="3" passed="2" failed="1" /> </ResultSummary> <TestDefinitions> <UnitTest name="CalcTestGroup::Multiply" id="fe6a2f48-7c29-4aac-a54f-c3c5b3ca876d"> <Execution id="ea9f9ae3-fc9a-4f80-a616-aec208705a3a" /> <TestMethod codeBase="c:/dev/pickles-results-harness/Pickles.TestHarness/Pickles.TestHarness.MSTest/bin/debug/Pickles.TestHarness.MSTest.DLL" adapterTypeName="Microsoft.VisualStudio.TestTools.TestTypes.Unit.UnitTestAdapter, Microsoft.VisualStudio.QualityTools.Tips.UnitTest.Adapter, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" className="Pickles.TestHarness.MSTest.AdditionFeature, Pickles.TestHarness.MSTest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" name="CalcTestGroup::Multiply" /> </UnitTest> <UnitTest name="CalcTestGroup::Subtract" id="0e043fed-0f1a-4a9e-9b83-d2a70ff0376e"> <Execution id="a2bd2fc2-724f-48df-86c0-d2eef5571a9c" /> <TestMethod codeBase="c:/dev/pickles-results-harness/Pickles.TestHarness/Pickles.TestHarness.MSTest/bin/debug/Pickles.TestHarness.MSTest.DLL" adapterTypeName="Microsoft.VisualStudio.TestTools.TestTypes.Unit.UnitTestAdapter, Microsoft.VisualStudio.QualityTools.Tips.UnitTest.Adapter, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" className="Pickles.TestHarness.MSTest.AdditionFeature, Pickles.TestHarness.MSTest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" name="CalcTestGroup::Subtract" /> </UnitTest> <UnitTest name="CalcTestGroup::Add" id="651a2fb3-6737-4c32-942d-333ffa6bc527"> <Execution id="e209f15e-6bab-4349-b180-76fb1e6b031a" /> <TestMethod codeBase="c:/dev/pickles-results-harness/Pickles.TestHarness/Pickles.TestHarness.MSTest/bin/debug/Pickles.TestHarness.MSTest.DLL" adapterTypeName="Microsoft.VisualStudio.TestTools.TestTypes.Unit.UnitTestAdapter, Microsoft.VisualStudio.QualityTools.Tips.UnitTest.Adapter, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" className="Pickles.TestHarness.MSTest.AdditionFeature, Pickles.TestHarness.MSTest, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" name="CalcTestGroup::Add" /> </UnitTest> </TestDefinitions> <TestLists> <TestList name="All Tests" id="ee45e271-96a6-4c28-9387-382e7b07f965" /> </TestLists> <TestEntries> <TestEntry testId="fe6a2f48-7c29-4aac-a54f-c3c5b3ca876d" executionId="ea9f9ae3-fc9a-4f80-a616-aec208705a3a" testListId="ee45e271-96a6-4c28-9387-382e7b07f965" /> <TestEntry testId="0e043fed-0f1a-4a9e-9b83-d2a70ff0376e" executionId="a2bd2fc2-724f-48df-86c0-d2eef5571a9c" testListId="ee45e271-96a6-4c28-9387-382e7b07f965" /> <TestEntry testId="651a2fb3-6737-4c32-942d-333ffa6bc527" executionId="e209f15e-6bab-4349-b180-76fb1e6b031a" testListId="ee45e271-96a6-4c28-9387-382e7b07f965" /> </TestEntries> <Results> <UnitTestResult executionId="ea9f9ae3-fc9a-4f80-a616-aec208705a3a" testId="fe6a2f48-7c29-4aac-a54f-c3c5b3ca876d" testName="CalcTestGroup::Multiply" duration="00:00:00" startTime="10/12/2019 15:39:06" endTime="10/12/2019 15:39:06" outcome="Passed" testListId="ee45e271-96a6-4c28-9387-382e7b07f965"> <Output> <StdOut> <Message>.</Message> </StdOut> </Output> </UnitTestResult> <UnitTestResult executionId="a2bd2fc2-724f-48df-86c0-d2eef5571a9c" testId="0e043fed-0f1a-4a9e-9b83-d2a70ff0376e" testName="CalcTestGroup::Subtract" duration="00:00:00" startTime="10/12/2019 15:39:06" endTime="10/12/2019 15:39:06" outcome="Passed" testListId="ee45e271-96a6-4c28-9387-382e7b07f965"> <Output> <StdOut> <Message>.</Message> </StdOut> </Output> </UnitTestResult> <UnitTestResult executionId="e209f15e-6bab-4349-b180-76fb1e6b031a" testId="651a2fb3-6737-4c32-942d-333ffa6bc527" testName="CalcTestGroup::Add" duration="00:00:00.1430000" startTime="10/12/2019 15:39:06" endTime="10/12/2019 15:39:06" outcome="Failed" testListId="ee45e271-96a6-4c28-9387-382e7b07f965"> <Output> <StdOut> <Message> Calc_Tests.cpp:19: error: Failure in TEST(CalcTestGroup, Add) expected <1 0x1> but was <2 0x2> </Message> </StdOut> <ErrorInfo> <Message> expected <1 0x1> but was <2 0x2> </Message> <StackTrace> at TEST_CalcTestGroup_Add_Test::testBody in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Calc_Tests.cpp:line 19 at helperDoTestBody in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 93 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at Utest::run in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 599 at UtestShell::runOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 211 at helperDoRunOneTestInCurrentProcess in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 118 at PlatformSpecificSetJmpImplementation in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\Platforms\Embedded\UtestPlatformEmbedded.cpp:line 144 at UtestShell::runOneTest in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\Utest.cpp:line 185 at TestRegistry::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\TestRegistry.cpp:line 87 at CommandLineTestRunner::runAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 124 at CommandLineTestRunner::runAllTestsMain in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 83 at CommandLineTestRunner::RunAllTests in C:\Users\Mark\AppData\Local\VisualGDB\TestFrameworks\com.sysprogs.unittest.CppUTest\src\CppUTest\CommandLineTestRunner.cpp:line 52 at main in C:\Users\Mark\.jenkins\workspace\Example_Pipeline\CICD_Test_UnitTest\Main.cpp:line 33 </StackTrace> </ErrorInfo> </Output> </UnitTestResult> </Results> </TestRun>
This reply was modified 6 years, 9 months ago by
support. Reason: formatting
December 10, 2019 at 17:36 #26843support
KeymasterThanks for finding this out. We have updated VisualGDB to create the TestMethod element as well (VisualGDB will only set the “name” attribute, as others are not relevant to the VisualGDB test logic). Please try this build: VisualGDB-5.5.2.3414.msi
If it still doesn’t work, please try manually adding other attributes present in the regular .trx file (e.g. codeBase, adapterTypeName) and let us know which combination of them fixes the problem, so that we could update VisualGDB to set them to some dummy values.
December 11, 2019 at 10:30 #26846Markg
ParticipantThanks for the update and quick fix! Just tested it and it works fine now. I will keep you up to date when we find any issues when we start using it for our production code.
December 11, 2019 at 18:33 #26851support
KeymasterNo problem. Let us know if you run into any issues and we will be happy to resolve them.
January 27, 2020 at 13:24 #27267Roman.Thiel
ParticipantThanks for the Update also from my side. I am now able to use “Publish MS Test result report” in Jenkins.
